mowerman1193 42 #1 Posted May 27, 2014 How does one know if it is the module or staiter? Is there a proceedure for testing what is actually bad or does one just throw some parts at it until they get it, LOL It started out as a intermitent problem.. but then just flat out no spark at all.. been sitting a couple years now since I came ill and many fix it projects was put on hold.. now I been trying to get things going again.. Kevin Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,974 #2 Posted May 27, 2014 Believe this is the manual you need. http://www.wheelhorseforum.com/files/file/3841-engine-kohler-cv11-cv16-sm-tp-2339-dpdf/ Good luck Garry (Sorry - had to change the link) Share this post Link to post Share on other sites
Save Old Iron 1,573 #3 Posted May 27, 2014 remove the kill wire from the magneto check for proper gap between magneto and flywheel and a good "pull" from the flywheel magnet if the engine has good cranking speed and you have no spark replace the magneto assy 1 Share this post Link to post Share on other sites
mowerman1193 42 #4 Posted May 28, 2014 Thanks for the replies.. I think I will go out in a little while and take the covers off and see if I can find something out.. Share this post Link to post Share on other sites
Save Old Iron 1,573 #5 Posted June 1, 2014 check the spark plug wire for bare areas caused by rodents chewing off the silicone casing the spark may be jumping to ground thru a chewed area on the plug wire Share this post Link to post Share on other sites
