can whlvr 994 #1 Posted May 26, 2014 so I put the tiller on my 312-h,ya I know its not a good idea on a hydro,very hard to control speed,but I wanted the hydro lift and I didn't want to remove my 2 inch receivers on 3 of my 8 speeds (thinking on pulling the trailer queen c101 out for tilling),so ive never had a problem with the lift or drive,it lifted the tiller just fine for about 10 minutes and now it will barely lift it,the cylinder is leaking fairly bad and allways has,but no fluid pours out when lifting,just wondering if anyone knows if the fluid can bypass inside the cylinder or valve,the hydro drive is full of fluid,new filter,new tranny fluid,the tractor has zero lag in the drive even when really hot,im gonna pull the tiller and try the plow or mower deck,hoping it aint a bad charge pump if the eaton 1100 has one??please help if you know anything Share this post Link to post Share on other sites
daveoman1966 3,880 #2 Posted May 26, 2014 (edited) pm sent... contact me directly at: daveoman@windstream.net Just click the link and subject line: 312-H lift Edited May 26, 2014 by daveoman1966 Share this post Link to post Share on other sites
