Countdown To Christmas!
canam1991
wheel horse d 250
canam1991
:banghead: has any one ever tried to make 3 pt arms for a d 250 sense they seen to be so rare?
WheelHorse_of_course
I'd assume the arms and the top link would be the eassiest part. The rest of the hitch not so easy...
:banghead:
Nick
The 3pt arms shouldn't be that bad to fab up if you could get the dimensions and some pictures to work from. You might even be able to modify arms from something else to work on the big D.
canam1991
well i was looking on ebay under 3 pt :banghead: and i came across a john deere set that looked very sim. :omg: but we all john deere parts on a wheel horse notgood :USA:
bell
Not to mention that JD parts are usually worth twice as much as they should be worth..... :banghead:
Bill
Don't know if you made your 3pt hitch for your 250 yet, But I made mine from a cat-0 hitch I bought at TSC.... works great
Teddy da Bear
I was consipating this very thought while at Rural King today....
I went to the 3pt. arm aisle.... There was flat stock about the
same length as the arms.... with holes at each end. Nor sure
but looked like you could mount the pivot balls at each end.
But would take something special. Also the flat stock could
be bent and shortened if needed.
canam1991
do you have any pictures?
Nick
What do the D250 3pt arms look like? I have pictures of the tractor but cant find any of the 3pt area. Are the 250 lift arms fairly straight or would they need bends similar to the smaller Ds lift arms?
I would assume less than 40 or so inches of 1/2" x 2" steel and 4 weld on ball sockets would do it. Think I paid around $5 each for the ball sockets at a local place.
Cat-0 Valu-bilt ball sockets
Bill
I just took some this morning, I'll email them to you
clintonnut
I have a brochure from '76 with the d-250 in it. If you looked at the 3pt arms they were like the gutbrods- ARROW STRAIGHT not bent. So you could have straight arms and use a rototiller but if you had a weight box, I think you might have to bend them.
Charlie
canam1991
I wonder if yuo can still order them but for the $$ its polly better to make them?
clintonnut
They are discontinued from toro.
Charlie
Nick
I must have missed the link to the 3pt picture. Kind of surprising they dont have a ball socket, just a hole drilled for the attachment pins.
The picture does show some pretty good bends in the arms. Thats something I hate doing in thick steel. :thumbs: If your the same way I bet you could just make a pattern from thinner material then have a welding shop build them at a fair price. Maybe also adding ball sockets as an improvement.
canam1991
Bill sent me some pics of the ones he built from tsc. they look good that will be my summer project....
sodbuster
if it will help.I have the measurements for arms off jd 318.I can email you.I have tried to post pics of them,havent figured it out yet. the ball sockets I used I purchased from kubota $7.35 ea.
maxblue
I am looking on getting another set of arms for my other D-250,A tractor dealer said that yarmar tractor may have a set that are close, but if all else fails I am have some made.I have a complete set up for one tractor now.
rickv1957
My 79 D250 has a 3pt but the arms have a couple of bends,look easy to make with a patteren,Rick
clintonnut
The early ones were straight. The main components you need are the arms, lift rods to go from the rock shaft to lift, and top link mount.
Charlie
