zbysiu23 3 #1 Posted May 22, 2014 Hi I am looking for a part # or specs for a starter belt for the 876.. The manual does not give the part nr. Any help would be appreciated.. Chris Share this post Link to post Share on other sites
Eric857 54 #2 Posted May 22, 2014 if you have the origional belt you can take it to napa or another auto or lawn and garden store and they will be able to match it for you. Also the belt itself should have the number on it. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,880 #3 Posted May 22, 2014 Wheel Horse 1583 nla Used on 6, 7, 8hp Kohler Starter generator {3Lx33" in belt chart should be 31-1/2"} 3V315 Gates .38"x31.5" 3V315 Napa .38"x31.5" Kohler #231605 Starter generator Replaces 232613 [.41"x32.08" 36 degree]* PSB #061 Should use raw edge belt 7315 Gates .41"x32.08" 36 degree 25-7315 Napa .41"x32.08" 36 degree Service bulletin One is wider than the other which would account for the longer length. Will add this to the manual notes for the 876 if it is correct so let us know what you do. Let us know. Garry Share this post Link to post Share on other sites
zbysiu23 3 #4 Posted May 23, 2014 Thank You very much!!! ..well since you have been so helpful.. there is another one.. The belt that engages the cutting deck through pulleys n foot pedal.. I have measured it at 27 in ?? does it sound correct?? Thank you Share this post Link to post Share on other sites
Eric857 54 #5 Posted May 23, 2014 that sounds right to me. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,880 #7 Posted May 23, 2014 32" mower 36" mower These may be the exact same manual so download one first to see and compare to the other. Belt charts with dimensions on the last pages Garry Share this post Link to post Share on other sites
