rustykan 140 #1 Posted May 22, 2014 Any secret tips for restoring the steering wheel on a C-120? Mine is in pretty good shape, but was wondering if there is any way to make it look better. Share this post Link to post Share on other sites
rmaynard 17,634 #2 Posted May 22, 2014 Soft wheel or hard plastic. Share this post Link to post Share on other sites
rustykan 140 #3 Posted May 22, 2014 I would say it is hard plastic. Share this post Link to post Share on other sites
bmsgaffer 2,071 #4 Posted May 22, 2014 That's actually the 'soft touch' wheel. The hard plastic are shiny and thinner. Share this post Link to post Share on other sites
rustykan 140 #5 Posted May 22, 2014 Learned something new! Share this post Link to post Share on other sites
shallowwatersailor 3,222 #6 Posted May 22, 2014 Here is a link to another forum on a quick and easy refreshing of a hard plastic wheel. http://www.orangetractortalks.com/2009/03/kubota-steering-wheel-restoration-tip/ 1 Share this post Link to post Share on other sites
Uncle Buck 246 #7 Posted May 23, 2014 That use of a torch on the wheel did not impress me in the least! I would simply knock off any rough spots with wet or dry sandpaper, then prime it, then paint it myself! I would use satin black. Share this post Link to post Share on other sites
rmaynard 17,634 #8 Posted May 23, 2014 Yup, that's the soft wheel. Clean it with soap and water. Let it dry, then get a spray can of VHT vinyl dye, satin black, and give it a couple of coats. It will look like new. Gloss black works well on the hard plastic wheels after roughing it up with a 3M Scotch-brite (gray) pad. 1 Share this post Link to post Share on other sites
slammer302 2,157 #9 Posted May 23, 2014 I'm going to buy some of this vinyl die today is the first I've heard about it Share this post Link to post Share on other sites
zipper 10 #10 Posted May 23, 2014 The VHT spray and the Elmers paint sticks works great. there is a detailed directions I found on this site someware Zipper Share this post Link to post Share on other sites
jdleach 525 #11 Posted May 25, 2014 Yup, that's the soft wheel. Clean it with soap and water. Let it dry, then get a spray can of VHT vinyl dye, satin black, and give it a couple of coats. It will look like new. Gloss black works well on the hard plastic wheels after roughing it up with a 3M Scotch-brite (gray) pad. Very true. On the hard wheels, they should last literally forever as long as you keep them out of the sun. To further protect a nice hard wheel, painting it is the best solution. While it may sound like a cheap, backyard hick remedy, one must remember that before steering wheels were made from plastic, they were hard rubber. To keep the rubber from blackening the paws of the driver, they were painted. I know, I have my Dad's 1949 Ford F-2 truck I am slowly restoring. The paint had worn off the wheel in places, and my hands would get as black as a coal miner's. The cracked and broken plastic wheels we see so often is mostly from UV (sun) deterioration. The wheel on my 312-8 is almost 30 years old, and still looks nearly new. The reason is it has always been kept inside when not in use. As stated earlier, adding paint will only increase the wheel's life. A good grade of paint will wear quite slowly from handling. The '49 Ford wheel was painted over a year ago, and still looks fresh, and I drive the truck several days a week to work. Share this post Link to post Share on other sites
c-series don 12,610 #12 Posted May 27, 2018 Can someone please elaborate on restoring a hard plastic steering wheel? I'm afraid to paint it, I feel like it won't stick good and peal off. Even if I scotch bright it. I'm restoring a 1984 Work Horse GT-1800. Any help is greatly appreciated! Share this post Link to post Share on other sites
JPWH 6,544 #13 Posted May 27, 2018 I painted a steering wheel after repairing damage from a dog chewing on it, that was 2 years ago and no peeling yet. I used rustoleum satin black. 1 Share this post Link to post Share on other sites
Sarge 3,473 #14 Posted May 28, 2018 For most plastics, an adhesion promoter is required to get the paint to "bite" properly. Some paints have enough acids to get the job done without it, but using a paint dedicated for plastic work would be your best bet. I did the wheel of a '68 WH Charger with the VHT vinyl dye, allowed that to dry for a solid day and top coated it with Eastwood's Diamond Clear. Wheel looks new to this day, that restore was done over 5yrs ago and it's seen a lot of sunlight/hard use. The real trick is to take your time when sanding, don't get in a rush and get it very evenly built up as your hands can find even the slightest defect when repairing cracks or missing pieces. Sarge Share this post Link to post Share on other sites
c-series don 12,610 #15 Posted May 28, 2018 Thank you Sarge, did you wetsand the wheel with 600 grit or something like that? Share this post Link to post Share on other sites
RandyLittrell 3,946 #16 Posted May 28, 2018 Use a grey scotchbrite pad and scuff it using soapy water, it scuffs easier and the soap cleans the oil and grime off which is the biggest reason paint does not stick. Randy 2 Share this post Link to post Share on other sites
Sarge 3,473 #17 Posted May 30, 2018 All the leveling was done prior to using the VHT vinyl dye - once that coating was applied it was allowed to dry and then top-coated with Eastwood's Diamond clear, no sanding for fear of damage to the color layer. I was pretty impressed how well the two worked together. You never know how well one chemical will bite into another and at times they do not get along - those two act like they were made for each other. Sarge 1 Share this post Link to post Share on other sites
Racinbob 13,250 #18 Posted May 30, 2018 I've done a few. I repaired any major dings with JB Weld, painted the spokes with Krylon for plastic and coated the rim with Dupli-Color truck bed liner. It looks and feels great and is as durable as most anything. 2 4 1 Share this post Link to post Share on other sites
Skipper 1,792 #19 Posted June 4, 2018 (edited) Bob, that bedliner solution is good thinking (don't want to say brilliant in public) Strong, wear resistant, and with the right looks and feel. Perfect! Do you mask it off like any other spray paint? I'm so gonna steal that idea............ Edited June 4, 2018 by Skipper 2 Share this post Link to post Share on other sites
Racinbob 13,250 #20 Posted June 4, 2018 I paint the spokes (if needed) without masking and then mask off the spokes for the bedliner spray. 1 Share this post Link to post Share on other sites
