yngliver 4 #1 Posted May 21, 2014 Hello! I posted a long while back about my new tractor and promptly went silent. I guess the long winter got the best of me. None the less I am back to work on my 312-h. I'm still having some starting issues that I'm not quite sure what to do about. I have discovered that if ground the starter, and run a wire from the hot of the battery to the starter post I can fire her up. Obviously somthing is happening inbetween, but that will have to be solved at another time. My issue at hand is about the rear hydraulic lift. I have the tiller attachment and my fiance is on my case to get a new garden plot in place. I hooked the tiller up with no troubles, aside from the missing belt which should arrive soon. I was mostly messing around tonight and lowered then raised the lift. Suddenly the tiller dropped to the ground! Long story short I found that the lift cable came detached from the lift lever where the chain was hooked. My question is about how to properly hook it back up. I found a diagram on parts tree and the end of my cable does not have the U shaped clevis but something round. More like a banjo almost. I hadn't really looked at it before so i'm not sure what goes where. I was hoping that someone could post a picture of their rear end (the tractor rear end of course!). Thanks for reading, sorry for the long winded post. Share this post Link to post Share on other sites
312Hydro 474 #2 Posted May 21, 2014 Will this help? Share this post Link to post Share on other sites
yngliver 4 #3 Posted May 21, 2014 That is perfect, Thanks! Share this post Link to post Share on other sites
