jdleach 525 #1 Posted May 18, 2014 Anyone who has followed my posts regarding my "new" 1985 312-8 Wheel Horse, knows that there has been several relatively minor problems I have addressed with the tractor since purchased. Headlight bezels, cable routing, missing knobs, blades, hood hinge refurb., taillight installation, etc., etc. I have moved progressively and methodically through them all, and have continually improved both the appearance, and the operation of my tractor. But this problem has me absolutely at a loss as to how to correct. I first noticed the problem right after I got the tractor and mowed for the first time. It was noted again last evening when I mowed. It occurs whether it is hot or cold out, daylight or dark. The problem is that I can only get about half way through a beer while driving the tractor before it goes flat. The vibration and bouncing of the tractor just destroys the fizz. Anyone else have this problem? What did you do about it? 5 Share this post Link to post Share on other sites
Sparky-(Admin) 24,659 #2 Posted May 18, 2014 Do you have a cup (can) holder? They are the worse thing cause all the bouncing and jolting gets absorbed by the can. I always hold the beer in my hand while mowing (and I don't have a fancy new machine with a can holder anyway). I have an 8 speed so I'm not grabbing for the hydro lever while holding the steering wheel with the other hand. Works for me. Solution #2 is to guzzle a bit faster like a college student....that works for me as well. Burping and belching because of the guzzling is perfectly acceptable! Mike......... 1 Share this post Link to post Share on other sites
Uncle Buck 246 #3 Posted May 18, 2014 Easy solution, get one of those hat holder thingies with the straw. You mount it to your head, hands free then sip and mow as you go! 4 Share this post Link to post Share on other sites
jdleach 525 #4 Posted May 18, 2014 Do you have a cup (can) holder? They are the worse thing cause all the bouncing and jolting gets absorbed by the can. I always hold the beer in my hand while mowing (and I don't have a fancy new machine with a can holder anyway). I have an 8 speed so I'm not grabbing for the hydro lever while holding the steering wheel with the other hand. Works for me. Solution #2 is to guzzle a bit faster like a college student....that works for me as well. Burping and belching because of the guzzling is perfectly acceptable! Mike......... HAR, HAR, Har.....Leaning toward the guzzling solution. 1 Share this post Link to post Share on other sites
Save Old Iron 1,573 #5 Posted May 18, 2014 4th order harmonically damped peltier based cooler with current controlled switch mode power source 5 Share this post Link to post Share on other sites
Lane Ranger 11,814 #6 Posted May 18, 2014 Stays cold throughout the mow! Magnetic and foam lined! Even if its not a beer! 2 Share this post Link to post Share on other sites
70wheelhorseGT-14 2 #7 Posted May 18, 2014 Drink more and often. 6 pack seems to be in your future before your finished cutting grass. Set a goal man!!!!! 2 Share this post Link to post Share on other sites
shallowwatersailor 3,220 #8 Posted May 18, 2014 Fabricate mechanical linkage to operate with the PTO lever, and either a smaller glass or a hose that can be used for direct intake. 1 Share this post Link to post Share on other sites
jdleach 525 #9 Posted May 18, 2014 Great solutions! Got to go mow now and try some of them out.... may miss work tomorrow though. 1 Share this post Link to post Share on other sites
AMC RULES 37,254 #10 Posted May 18, 2014 Focus on the task at hand... then, reward yourself with a cold one... once the work is done. Share this post Link to post Share on other sites
km3h 543 #11 Posted May 18, 2014 Simple solution!!!! YOU ARE NOT DRINKING THE BEER FAST ENOUGH. CUTTING GRASS IS NOT LIKE BEING IN A BAR. YOU DON'T HAVE TO NURSE IT TO SAVE MONEY. 1 Share this post Link to post Share on other sites
squonk 45,590 #12 Posted May 18, 2014 I can see it now. Drink faster and consume a sixer. Then complain because the "Lines aren't straight!" 2 Share this post Link to post Share on other sites
nylyon-(Admin) 8,836 #13 Posted May 18, 2014 That's why I like my Onan's, they have a 48% increased beer carbonation retention rate compared to a 16 horse Kohler. 59% greater than a Briggs and can't measure against the Techies.... I think it also has to do with can or bottle (let's not go there again), but a can will likely lose more fizz than the bottle and you run a higher risk of thermal loss due to the propertied of the can. It is important therefore to keep a koozie on the bottle , Unfortunately, the koozie doesn't keep the top of the bottle protected, and many place little umbrella's over. HEAT = Loss of carbonation. Ask our UK friends with their "cellar temperature" I'll bet they can't even get 2 laps down before POW flat! And of course, as mentioned you are likely consuming at a slower rate than recommended. There's a chart around here some where with the proper ratio's with respect to time and temperature. 2 Share this post Link to post Share on other sites
nylyon-(Admin) 8,836 #14 Posted May 18, 2014 But ya gotta be careful too: Share this post Link to post Share on other sites
Tim 97 #15 Posted May 18, 2014 what one person sees as a problem, other see as an opportunity you are seeing the glass half empty others half full Share this post Link to post Share on other sites
Digger 66 3,525 #16 Posted May 18, 2014 Have the misses hold your beer & with each lap , take a sip & kiss the holder . 4 Share this post Link to post Share on other sites
papaglide 542 #17 Posted May 18, 2014 This is fantastic. I am so glad that I am not the only person with this problem. Share this post Link to post Share on other sites
smoreau 658 #18 Posted May 19, 2014 A friend of mine has solved this long time problem!! He installed a post in his yard that he sets his beer on and stops at the post for a drink every lap! His only problem is he has more laps then drinks from 1 Can of beer. So He added two more posts in different spots and he has 3 cans in cozies to last all his pit stops cutting 2 acres with no flat beer! 2 Share this post Link to post Share on other sites
WH nut 553 #19 Posted May 19, 2014 Anyone who has followed my posts regarding my "new" 1985 312-8 Wheel Horse, knows that there has been several relatively minor problems I have addressed with the tractor since purchased. Headlight bezels, cable routing, missing knobs, blades, hood hinge refurb., taillight installation, etc., etc. I have moved progressively and methodically through them all, and have continually improved both the appearance, and the operation of my tractor. But this problem has me absolutely at a loss as to how to correct. I first noticed the problem right after I got the tractor and mowed for the first time. It was noted again last evening when I mowed. It occurs whether it is hot or cold out, daylight or dark. The problem is that I can only get about half way through a beer while driving the tractor before it goes flat. The vibration and bouncing of the tractor just destroys the fizz. Anyone else have this problem? What did you do about it? Have the same problem, you just have to drink faster. Share this post Link to post Share on other sites
thehorse 221 #20 Posted May 19, 2014 I strategically mow around the property. Two laps....have a beer. Always holding it so it doesn't go milkshake on me! Share this post Link to post Share on other sites
Wheel-N-It 2,978 #21 Posted May 19, 2014 Never have that problem here. Moonshine does not go flat. 3 Share this post Link to post Share on other sites
64s 83 #22 Posted May 19, 2014 I just drink enough beforehand so that the grass already looks cut. 2 Share this post Link to post Share on other sites
Jrblanke 918 #23 Posted May 19, 2014 Another vote for the foam dome beer helmet! Although I do think Van is on to something... 1 Share this post Link to post Share on other sites
MalMac 1,334 #24 Posted May 19, 2014 I am with Wheel-N-it, Shine does not go flat and when the tractor needs that little extra RPM while in tall grass you can just add a we little bit to the gas tank. 2 Share this post Link to post Share on other sites
