engineguy63 238 #1 Posted May 18, 2014 OK guys, Bought the thing and its home. I think I got a pretty good deal because the engine cooling shroud was so filled with acorns and mouse nests we could hardly get it to turn over with a wrench. Battery is junk. I made an offer that was accepted, and brought it home and removed the fan screen and was amazed at how much crap mice brought into it. Tommorrow I will remove the cowling and see if I can clean it out...its turning pretty smooth now and I feel good compression, but can really only go back and forth as theres still some stuff blocking it from turning smoothly all the way over. Just hoping its not a dropped valve or something really bad, but, I feel reasonable good about it. It has a P216 onan engine, hydro drive and deck lift. rear discharge deck looks about 48" but I believe the model is 78350, tractor #73421 4900422 serial number. Can someone tell me what year this tractor is. Once I get her goin' again I will want to get a recycler deck or convert kit for this one. What do we think? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,012 #2 Posted May 18, 2014 Operator manual Garry Share this post Link to post Share on other sites
Tankman 3,528 #3 Posted May 18, 2014 Good luck, nice Horse! Hope you didn't purchase a pig in a poke. Let us know how you make out. Again, good luck, forward march! Share this post Link to post Share on other sites
km3h 543 #4 Posted May 18, 2014 (edited) I think you got a pretty nice tractor there. I just picked up one like it 2 weeks ago. The tin on that engine is difficult to remove. Make sure you remove the hood to make it easier to do. Like you I found so much junk inside the engine covers I could not imagine that it would run long because of the heat buildup. How many hours on the meter? Had a few ele3ctrical problems but finally got her running and cut grass with it yesterday. Today I cut part of a field where the grass was 16 inches high. Had to run it slow so as not to miss any but it sure did the job without a moan or groan. Edited May 18, 2014 by km3h 1 Share this post Link to post Share on other sites
Kelly 1,037 #5 Posted May 18, 2014 Looks good from here unless you paid more than $400 I'd say your ok, even if it don't run, I see a $250+ deck if it's as nice as it looks Share this post Link to post Share on other sites
nylyon-(Admin) 8,835 #6 Posted May 18, 2014 I'm pretty sure that's a 1994, and it's a 42" RD deck, get the recycler insert and you're good to go! It looks like it's sat outside for a while, but I think it''' dean up nicely. I have a 1994 416H as well and I love it! There doesn't seem to have the issues with the valves as the P220 does. Share this post Link to post Share on other sites
Martin 2,133 #7 Posted May 18, 2014 yes Karl is right its a 1994...... 73421 (416-H) - Toro 416-H Garden Tractor, 1994 (4900001-4999999) just be careful turning it over if it won't turn easy a full revolution. you might have something internal stopping it from doing a full circle, but for your sake, lets hope not........ looks like it will clean up nice, the 416 is definitely my favorite 1990s tractor.... Share this post Link to post Share on other sites
nylyon-(Admin) 8,835 #8 Posted May 18, 2014 Oh, and mine is serial number 4900479 just 57 units newer! Share this post Link to post Share on other sites
engineguy63 238 #9 Posted May 18, 2014 Well tomorrow is another day and well see how she goes. When I turn the engine over, with a wrench and it stops...it does not have a metallic sound like metal on metal....seams to be maybe some big glob of some mouse nest wont pass through a narrow area of the shrouding......at least that's what I am hoping..................Just out of curiosity....is a 520 a bigger unit or just a bigger engine, I just missed one go at an auction...same price as what I paid for this one.......$200, and apx..and same condition, also an ONAN engine....but slightly more crappie deck. Share this post Link to post Share on other sites
nylyon-(Admin) 8,835 #10 Posted May 18, 2014 Newer 520's have a swept forward axle, reduced effort steering, 1" front spindles, 10.50 rear tires, gauges etc... With the exception of a 60" deck, your 416 will do the same work! Share this post Link to post Share on other sites
km3h 543 #11 Posted May 18, 2014 Have you tried removing the plugs? If the plugs are in it, it might be that there oil or water in the cylinders or even gasoline. Just a thought. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,012 #12 Posted May 18, 2014 More manuals for the 1994 416-H If you search the manuals library for 73421 there are more for 1994 but it may take a couple of days for them to show up. Garry Share this post Link to post Share on other sites
nylyon-(Admin) 8,835 #13 Posted May 18, 2014 Well, if you decide not to mess with it, I'll give ya what you paid for it Share this post Link to post Share on other sites
engineguy63 238 #14 Posted May 19, 2014 I figured it was a REASONABLY safe investment. Anyhow, today I loosened the shroud so I could do a reasonably good vacuuming of the area, and wow what a mess! Mouse nests galore, hay, dirt, and lots of acorns. Looks like it NEVER got a decent cleanout. Oil however was VERY clean and the hydro fluid seamed VERY clean as well....no indication of water in either. I got encouraged and turned the engine over with a socket wrench...got tight in one spot so I went the other direction...back and fourth a few times each time gaining ground and now it spins pretty good. Took the plugs out one at a time and one cylinder has great compressin and one is a bit weeker, so mayby that cylinder is still a little dry, or rings are stuck....who knows. Tommorrow I will put some jumpers on it and see if it sounds good turning over and to check for spark....if alls good, will toss in some fuel and see what happens! Share this post Link to post Share on other sites
engineguy63 238 #15 Posted May 19, 2014 oh yeah 522 hours on the clock..........I have been told its been a sittin a while!!! Share this post Link to post Share on other sites
Martin 2,133 #16 Posted May 19, 2014 (edited) i never like to force an engine to turn over, could cause other problems or damage...... you could have had a valve that was stuck open a little. that would explain why you could go only so far in one direction and then in the other. could have slowly worked it loose...... i would check them if you have the heads off. if i get an engine that turns over like that and won't do a full revolution, removing a head usually will show up which one is stuck, (or expose another problem that is causing it to get stuck) ive also had corrosion and junk sitting in the upper cylinder and stopping a piston from reaching tdc. Edited May 19, 2014 by Martin Share this post Link to post Share on other sites
km3h 543 #17 Posted May 19, 2014 oh yeah 522 hours on the clock..........I have been told its been a sittin a while!!! That's amazing. The one I just got had 520 hours on it. Had been sitting 5 years. I sprayed oil in the plug holes and then let it sit for two days. Left the plugs out and cranked it a few times before I put the plugs back in. The Gas tank was bone dry, like someone had drained it when they last used it. Took some turns getting fuel up to the carburetor. I actually squirted some gas in the carburetor to prime it and it fired right away. Smoked a bit till it burned away the oil and now it is !00% good. Share this post Link to post Share on other sites
Fordiesel69 271 #18 Posted May 19, 2014 You should also remove the shroud and degrease , wash the fins. Vacuuming is not enough. After running it, the compression should come back a little. Share this post Link to post Share on other sites
engineguy63 238 #19 Posted May 19, 2014 Thanks Guys, My intent would be to find out the general "run worthiness" of this horse. If it fires and seams decent,I will probably run very lightly over the summer and then pull the engine and take all the shrouds off, lap the valves , rebuild the carb, new gas lines filters etc over the fall/winter. It is much cleaner now under the shrouds than it has been in years...I am sure of that. Will pull the plugs this am and squirt a little "marvel mystery" in there and try cranking...without plugs,,later and see if spark is there and what it sounds like. Because it is a flathead I knew having a hung valve hitting the piston would not be an issue....would only mean lack of compression. My guess is I have a dry cylinder or maybe a little corrosion started on a cylinder wall....and possible stuck rings.............either way a little oil should clean it out pretty well without having to do a major teardown......(hopefully). My experience with gas engines is more torward old one lungers...........but.....should not be ALL THAT DIFFRENT. Share this post Link to post Share on other sites
engineguy63 238 #20 Posted May 19, 2014 I Guess this tells the story, Despite the awful quality of the video, she just purrs. https://www.youtube.com/watch?v=sVoAqLjcEvI&feature=youtu.be still have to free up the hydro controls....they seam stiff, but work ok! Share this post Link to post Share on other sites
nylyon-(Admin) 8,835 #21 Posted May 19, 2014 Your video is marked private Share this post Link to post Share on other sites
engineguy63 238 #22 Posted May 19, 2014 Try It here, My account is a public account, I just checked it again..... https://www.youtube.com/edit?o=U&video_id=sVoAqLjcEvI Thanks Share this post Link to post Share on other sites
km3h 543 #23 Posted May 19, 2014 It sure does purr. Nice running engine. Share this post Link to post Share on other sites
rexman72 210 #24 Posted May 19, 2014 that's a good looking tractor Share this post Link to post Share on other sites
engineguy63 238 #25 Posted May 20, 2014 Thanks Everyone, It was easier than I thought to get it goin' I am VERY impressed with the quality of these old machines! Built to last with Iron and steel! If I want to get some impliments for it how can I tell what fits...is there a certain model # to look for on the mower decks, tillers plows and snownblowers? I see a lot of attachments at swap meets just don't want to buy stuff that wont work with it. I am needing a mulch (recycler) kit for my rear discharge deck, is that still available at old fashioned toro/wheelhorse dealers or is it obsolete and can only get from other collecters? Thanks again Share this post Link to post Share on other sites
