slammer302 2,157 #1 Posted May 16, 2014 I'm in need of a print or some measurements for the mounting plates for a cbr-32 front mount sickle mower the one I brought was rigged up on a front engine WH so I did not get the hanger plates I believe the part number is 2239 any help will be appreciated Share this post Link to post Share on other sites
dclarke 4,268 #2 Posted May 17, 2014 Hope these help, some of these pics might be repetitive. . The 1/4" nut welded to the right plate is where one end of the spring goes. Otherwise the plates are the same. 1 Share this post Link to post Share on other sites
slammer302 2,157 #3 Posted May 17, 2014 That will help alot I will get to making a cnc plaz program so I can cut a set out Share this post Link to post Share on other sites
slammer302 2,157 #4 Posted May 17, 2014 Do you have any drawings of clutch hardware like how long the 1/2 rod is Share this post Link to post Share on other sites
