squonk 43,797 #1 Posted May 12, 2014 My 704's hood rattles /vibrates something awful. Mainly at the higher throttle settings. It's quite annoying. I have the hood off of it now trying to diagnose a fuel issue but that's another story. I may have solved that but I'm not going to jinx myself yet. The bottom mount is solid no broken welds. The 2 holes by the steering wheel has some small cracks and i welded washers behind them before it was painted. I'm using the std issue thumbscrews. I have though about using some rubber washers and some spring washers to try to soak up some of the vibes. I was wondering if any one else has tackled this problem and how they resolved it? Share this post Link to post Share on other sites
Kelly 1,033 #2 Posted May 12, 2014 I have used cone washers with a rubber back on them, I get them at Fastenal, I tried O rings that works as long as you don't take it off often. Share this post Link to post Share on other sites
squonk 43,797 #3 Posted May 12, 2014 Do you use them under the hood or under the bolts? Share this post Link to post Share on other sites
