kidscruiser 1 #1 Posted May 11, 2014 First time owning a wheel horse. The shifter broke off at the ball and rollpin can i pull the bottom piece out that I can feel with my finger. Or do I have to split case PLEASE HELP Share this post Link to post Share on other sites
stratostar250 934 #2 Posted May 11, 2014 (edited) If you are sure if you can feel it, be careful and try to snag it, that way you wouldn't have to open the case, but yes, the collar around the shifter will fit thru the opening. Mine fell in, and therefore I had to crack mine, which really isn't a big deal, if need be, everyone I'm sure will help you here, there is for sure enough info! Edited May 11, 2014 by stratostar250 1 Share this post Link to post Share on other sites
kidscruiser 1 #3 Posted May 11, 2014 THANKS. Yeah I believe that is what I feel. It has a slot in it as if it straddled the rollpin. Its just fell down a little but thanks for the info I'm knew to the site and to the tractor sure y'all will get to know me lol thanks again 1 Share this post Link to post Share on other sites
546cowboy 302 #5 Posted May 11, 2014 Have you got one of those extendable magnets? Like this one http://www.harborfreight.com/15-lb-capacity-telescoping-magnetic-pickup-tool-95933.html It should be able to pull it out of there. 1 Share this post Link to post Share on other sites
KC9KAS 4,746 #6 Posted May 11, 2014 Nashville.....Indiana or Tennessee? Share this post Link to post Share on other sites
kidscruiser 1 #8 Posted May 11, 2014 Thanks for the welcoming Share this post Link to post Share on other sites
kidscruiser 1 #9 Posted May 11, 2014 Thanks for the welcoming Share this post Link to post Share on other sites
WheelHorse_of_course 100 #10 Posted May 13, 2014 Of course you will not be able to pull it out till you loosen the lock not and then the bolt (IIRC this has an allen head) good luck. Rolf Share this post Link to post Share on other sites
