Desko 636 #1 Posted May 8, 2014 (edited) Hey all. I have recently got a cub cadet 71 for free I know its not red but it has the k161 and the points need cleaned and adjusted it has been sitting in the weeds for 7 years and is in really rough shape. This Is my first Kohler motor and I have no clue about them. Thanks in advance Edited May 8, 2014 by Desko Share this post Link to post Share on other sites
Jake Kuhn 1,581 #2 Posted May 8, 2014 points are .020 and plug is .025 Share this post Link to post Share on other sites
Desko 636 #3 Posted May 8, 2014 Thanks anything else to check on the motor Share this post Link to post Share on other sites
gregg'shorses 77 #4 Posted May 9, 2014 Go to www.kohlerengines.com and download for yourself an owners and service manual. 1 Share this post Link to post Share on other sites
rick 258 #5 Posted May 10, 2014 I am NOT trying to start an argument with this post- Setting the points at.020 will let the engine run, BUT the engine will operate better when the points open at the proper time in the firing cycle. Kohler K engines have a timing mark, an S and a line on the flywheel. When this line is aligned with the timing mark on the bearing plate the crankshaft is in the proper position for the points to open. There is an opening in the blower cover through which the marks can be aligned. READ the book! I am not saying the engine won't run with the points set at .020, I am only trying to say that not all engines will run well at .020 point gap. I know from experience it isn't so. Share this post Link to post Share on other sites
rmaynard 16,695 #6 Posted May 10, 2014 The above method is referred to as "static timing" there is a procedure that has been posted on the internet that explains in detail how to do it. I find that static timing is much better than just setting points to .020. Here is a link courtesy of Matt Gonitzke: http://mgonitzke.net16.net/tools/static_timing.pdf 1 Share this post Link to post Share on other sites
rick 258 #7 Posted May 11, 2014 If the timing mark is easily seen, a timing light can be used to set the points with the engine running. You need a self powered timing light or battery to power the light, if the piece of equipment doesn't use one. Share this post Link to post Share on other sites
