Firemanjohn 0 #1 Posted May 7, 2014 I do not know why, it was low on oil but not out but I have my favorite tractor a Raider 10 that seized the motor (Tecumseh HH10) after 5 minutes of running when I moved it out of the way to work on another project. I am in the process of disassembly and so far my 2 questions are; What is the best way to remove the clutch pulley (manual clutch) from the crankshaft? I am thinking a bolt puller and some threaded rod into the holes that hold the shims for the clutch facing. And refresh my memory is the flywheel a left hand or standard thread? Thank you everyone. John Share this post Link to post Share on other sites
pfrederi 19,759 #2 Posted May 7, 2014 (edited) I don't have an HH10 but my HH70 60 and H60's are all standard thread on flywheel. The official Techy flywheel puller is a closed end nut like contraption. After you get the flywheel nut off you run this thing down until it touch the flywheel then back it of 1/4-1/2 turn and whack it with a hammer. Most of the time that will do it if not you are allowed to pry on the edge of the flywheel while you whack it again. Edited May 7, 2014 by pfrederi Share this post Link to post Share on other sites
