pinecone 26 #1 Posted May 5, 2014 i have a 42" deck with 3 blades. is there a best pattern to set them at for balance and discharge. planning to change them and thought i'd ask the pros. i can screw anything up if i try hard enough. tks Share this post Link to post Share on other sites
cleat 7,706 #2 Posted May 5, 2014 I would think that it does not matter. The blades ban move anyways unless you have a timing belt setup a belt can slip and the blade can move. Just make sure each blade is balanced, put a little never seize on the shaft threads before installing the blade for ease of removal later. Cleat Share this post Link to post Share on other sites
pinecone 26 #3 Posted May 5, 2014 tks cleat. i think i will try a 120 degree differance for starters but will photo how they are now in case. Share this post Link to post Share on other sites
Kelly 1,033 #4 Posted May 5, 2014 they will not stay, I just put them on, never had a problem. Share this post Link to post Share on other sites
jrc0528 20 #5 Posted May 5, 2014 (edited) Ditto^^ Anytime one blade gets into a thicker patch of grass it will tend to slip slightly on the belt. Just for kicks, set a pattern, go mow for a while (try to load the motor in a nice heavy area as well) then pull the deck and check the pattern. My money says it will have changed! Edited May 5, 2014 by jrc0528 Share this post Link to post Share on other sites
rwilson 128 #6 Posted May 5, 2014 the only WH blades you need to align are the gear drive decks. Share this post Link to post Share on other sites
smoreau 658 #7 Posted May 5, 2014 (edited) The blades will change in 1 revaluation. The center pulley is a different size then the two outside ones. That is how both my 42 and 48 side discharge are. My 36 side has the same pulleys for all 3 I think, but I may be wrong, it's been a while cense I looked at that one. Edited May 5, 2014 by smoreau Share this post Link to post Share on other sites
pinecone 26 #8 Posted May 6, 2014 tks all for the info. Share this post Link to post Share on other sites
PaulC 342 #9 Posted May 6, 2014 after some reading here on the site I was gonna try a dual blade setup?? like 3 little helicopters running under my 42" rear discharge deck. anyone have opinions on this? will I have issues with the 2 blades on the same spindle shifting to where they wouldn't be a true "X" anymore and then throwing everything off balance? Share this post Link to post Share on other sites
bmsgaffer 2,054 #10 Posted May 6, 2014 after some reading here on the site I was gonna try a dual blade setup?? like 3 little helicopters running under my 42" rear discharge deck. anyone have opinions on this? will I have issues with the 2 blades on the same spindle shifting to where they wouldn't be a true "X" anymore and then throwing everything off balance? It wont throw anything off balance as the whole blade will slip, so the opposing forces will always be equal. The only thing that will cause a problem (and a big one) is if the blade slips enough to contact the "twist" of the blade below it. I could see that if you hit a stump and the bottom blade stops spinning (even for a brief second) the top blade will probably fly very fast into the "wing" of the blade below it and probably destroy both of them... Share this post Link to post Share on other sites
smoreau 658 #11 Posted May 6, 2014 Glen uses the double blade set up on his and has been very happy with the set up Share this post Link to post Share on other sites
PaulC 342 #12 Posted May 6, 2014 It wont throw anything off balance as the whole blade will slip, so the opposing forces will always be equal. The only thing that will cause a problem (and a big one) is if the blade slips enough to contact the "twist" of the blade below it. I could see that if you hit a stump and the bottom blade stops spinning (even for a brief second) the top blade will probably fly very fast into the "wing" of the blade below it and probably destroy both of them... Both of these statements make sense, especially the first one. Glen uses the double blade set up on his and has been very happy with the set up do you know if Glen has done anything to the blades to make sure the above suggestion doesn't happen? I had the thought that I could drill small holes beside the center bolt hole and bolt the two blades together? Share this post Link to post Share on other sites
cleat 7,706 #13 Posted May 6, 2014 Some commercial mowers come this way. I would think that if the blades move together it would just mimic a real thick single blade. I might try this on my 72" finishing mower on the diesel tractor. Cleat Share this post Link to post Share on other sites
