jrfan882008 2 #1 Posted September 19, 2008 got a project in mind does the tranny gear ratio change from year to year :banghead: Share this post Link to post Share on other sites
Curmudgeon 28 #2 Posted September 19, 2008 There were some minor changes between transmissions. If you're thinking of interchanging parts, I'd recommend looking at the parts lists and seeing if the numbers are the same. OR. Do as I did, just pull the trannies apart and see if they'll fit. I know I've exchanged parts between differeing trannies before. No problem. That doesn't mean everything will every time though. Share this post Link to post Share on other sites
kpinnc 15,669 #3 Posted September 19, 2008 Also, if you don't already have the mechanical transmission manual, you can copy it from HERE. It has the ratios for each gear, on several different transmissions. If your ratios match, you're all set. Kevin Share this post Link to post Share on other sites
jrfan882008 2 #4 Posted September 20, 2008 had in mind hookin 2 together will it matter if there not same year trannys Share this post Link to post Share on other sites
