BGrizzleC105 5 #1 Posted May 2, 2014 Hello I'm having an issue that i've never come across before I recently rebuilt my carb and it spewing fuel and i have checked and replaced every thing on it and Just went out and bought a brand new carb and am still have this issue any help would be awesome Share this post Link to post Share on other sites
slammer302 2,156 #2 Posted May 2, 2014 What motor do you have Share this post Link to post Share on other sites
rmaynard 16,549 #3 Posted May 2, 2014 I am assuming from your name that you have a C-105 with a K241. Did you rebuilt the carburetor because it was spewing fuel? Share this post Link to post Share on other sites
rmaynard 16,549 #4 Posted May 2, 2014 (edited) Here is a recent thread with basically the same issue. Can't see a new carb doing the same thing unless the new carb has a float or float valve issue right out of the box. Do you have an original mechanical fuel pump on it? Edited May 2, 2014 by rmaynard 1 Share this post Link to post Share on other sites
Desko 624 #5 Posted May 2, 2014 Welcome to RedSquare and could it not be gassy oil blowing out the breather and or does it have an electric fuel pump added to it if it does the pump may be building to much pressure. Share this post Link to post Share on other sites
BGrizzleC105 5 #6 Posted May 2, 2014 I rebuilt the carb because of water damage have rebuilt before and never had a problem and so I figured the new carb would work and it did until today so I will check out the link thank you Share this post Link to post Share on other sites
BGrizzleC105 5 #7 Posted May 2, 2014 It a K241 and it dose not have a electric pump that why I'm at a loss Share this post Link to post Share on other sites
BGrizzleC105 5 #8 Posted May 2, 2014 Thank you Guy's I'm going to take the carb a part on friday I'll Try to post pic and thank you so much 1 Share this post Link to post Share on other sites
BGrizzleC105 5 #9 Posted May 3, 2014 (edited) Ok guys checked the float and made sure it was clean and it still doing it any other suggestion. Next question could it be a problem with the mechanical fuel pump I a greatfull for the advise. Edited May 3, 2014 by BGrizzleC105 Share this post Link to post Share on other sites
BGrizzleC105 5 #10 Posted May 6, 2014 Got My Hands on another float fixed problem Thank you for the help Share this post Link to post Share on other sites
rmaynard 16,549 #11 Posted May 6, 2014 Glad to be able to help. It's always good to hear back from someone when a problem is solved. Makes it easier for the next guy with a similar issue. Thanks. 1 Share this post Link to post Share on other sites
