KC9KAS 4,744 #1 Posted April 26, 2014 Just received a slot to sleeve adapter for my Brinly plow. 7 Share this post Link to post Share on other sites
squonk 43,850 #2 Posted April 26, 2014 That 's a different style adapter that I haven't thought of. I always see the slot bars that have the pin hole and adjusting bolts in them. Looks awesome! Now lets see it in action! Share this post Link to post Share on other sites
KC9KAS 4,744 #3 Posted April 26, 2014 That 's a different style adapter that I haven't thought of. I always see the slot bars that have the pin hole and adjusting bolts in them. Looks awesome! Now lets see it in action! I am not sure if this is factory or homemade, but the vertical piece is welded at a slight angle so the plow sits even side to side when the right wheel is in the furrow. When I bought this I thought I was getting the type you are refering to, but this will work too! Share this post Link to post Share on other sites
squonk 43,850 #4 Posted April 26, 2014 If you look at the piece you took off the plow you will see the "twist" in it so the plow sits level. Is that the plow with the depth wheel? Share this post Link to post Share on other sites
KC9KAS 4,744 #5 Posted April 26, 2014 If you look at the piece you took off the plow you will see the "twist" in it so the plow sits level. Is that the plow with the depth wheel? Yeah, the piece for the sleeve hitch had a bit of an angle to it....same as this piece. and yes, this plow has the depth gauge wheel. 1 Share this post Link to post Share on other sites
squonk 43,850 #6 Posted April 26, 2014 OK!! Is there a plowing video coming soon? Share this post Link to post Share on other sites
KC9KAS 4,744 #7 Posted April 27, 2014 OK!! Is there a plowing video coming soon? Not sure. We don't put out a garden and I already plowed dads last fall. I could go over to the neighbors front lawn....or maybe the church yard up the street....... Share this post Link to post Share on other sites
Tankman 3,523 #8 Posted April 27, 2014 Used the same setup 40 years ago, slot hitch. I used one wheel and plow from an old farm gang. Bent a piece of flat bar and welded it to the plow assembly. Worked fine but, was I surprised, my first attempt at plowing front wheels were a foot (or more) in the sky!. Second plowing I had front weights on the old Horse. Made a frame, bolted to the Horse's front frame, that held several suitcase weights. I was, and the neighbors were, amazed watching the 8 HP Wheel Horse plowing. That old Horse did a great job besides infecting me with WHA (Wheel Horse Addiction). Share this post Link to post Share on other sites
MalMac 1,332 #9 Posted April 27, 2014 I have an adapter just like that. it's factory original. I myself I like the slot adapter over the clevis. I have used both. Share this post Link to post Share on other sites
KC9KAS 4,744 #10 Posted October 10, 2014 I have an adapter just like that. it's factory original. I myself I like the slot adapter over the clevis. I have used both. Do I have in installed correctly, or do I have it upside down? Reason I asked....I tried to plow with it this way and couldn't get the plow to go more than 2-3" deep.... Share this post Link to post Share on other sites
AMC RULES 37,196 #11 Posted October 10, 2014 Flip it, see what happens. Share this post Link to post Share on other sites
