Buzz 503 #1 Posted April 26, 2014 What gas cap are you using on your 854 and other tractors with that style tank? I have been using one from TSC that fits a Ford but not real happy with it, It doesn't fit as tight as it should and gas can seep out if tank is over 3/4 full. Any suggestions? Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,590 #2 Posted April 26, 2014 buzz, good question as I am in the same predicament. The gas cap on my 854 is pretty beat up, loose fit and I remember how the gas used to slop out the top at the neck also. Been looking myself for some time. Will be following this. Glenn Share this post Link to post Share on other sites
64s 83 #3 Posted April 26, 2014 My cap was loose also, so I got some fuel proof rubber gasket material, cut it to size, and slipped it into the cap. Tightened right up. Share this post Link to post Share on other sites
dclarke 4,274 #4 Posted April 26, 2014 I used this one from NAPA on my 701 until I found a nice original and it does fit tight on my 854 tank. Share this post Link to post Share on other sites
specialwheelhorse 174 #5 Posted October 4, 2014 I think your local Harley dealer will have what you need !!! Share this post Link to post Share on other sites
buckrancher 2,697 #6 Posted October 5, 2014 modified john deere radiator cap exact copy of original Brian 1 Share this post Link to post Share on other sites
buckrancher 2,697 #7 Posted October 5, 2014 hard to get a good picture with the glare from the chrome but here it is you need to drill two small holes for a vent one in the center and one just at the edge of the red tank seal gasket if you have a original look at the bottom of it and copy Brian Share this post Link to post Share on other sites
