Lagersolut 793 #1 Posted April 21, 2014 My 2005 classic GT is driving me crazy - acted like the solenoid was bad, replaced it, same problem - juice everywhere, but not the starter when turned to start - seat switch- reverse shut off- both jump wired shut - neutral switch checked good for continuity - I have over 12 volts coming out of the start terminal on the ignition into the relays but nothing at the starter side solenoid ( this problem comes and goes - had to quit looking ... decided to start working again tonight ) I can hear the relays " clicking " when turned to start - . I'm no electrician by any stretch , do have a multimeter and can do the basics - right now I'm wondering what and where else to look - cross solenoid terminals - fires right up . Any ideas where this circuit is open ( at times ) not starting ? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,989 #2 Posted April 22, 2014 Here is a detailed wiring diagram. The starter circuit has it's own diagram making it easier to trace. Garry Share this post Link to post Share on other sites
Lagersolut 793 #3 Posted April 22, 2014 Thank you Gary , I was going off the full wiring diagram diagram in the owners manual making it very difficult to isolate the starter circuit it start mode ....that's the ticket Share this post Link to post Share on other sites
bmsgaffer 2,069 #4 Posted April 22, 2014 I had a bad PTO interlock switch on one that cause intermittent starts (with clicking) It was on an older C series, but since that was the one safety switch you didnt mention, I thought it would be worth a look. Share this post Link to post Share on other sites
Lagersolut 793 #5 Posted April 22, 2014 I had a bad PTO interlock switch on one that cause intermittent starts (with clicking) It was on an older C series, but since that was the one safety switch you didnt mention, I thought it would be worth a look. This newer model has a PTO lock-out too, I was having a hard time deciphering which terminals needed to be checked for continuity , the owners manual diagram is very confusing and the thing decided to start working again - I'm down to that or the parking switch- if they check good I don't know where else to go but the relays - it has 4, not going to be easy to find - the PDF file Gary posted has the circuits broke down in separate diagrams for " run " start " " off " etc. Share this post Link to post Share on other sites
squonk 45,391 #6 Posted April 22, 2014 Doesn't take much dirt/ corrosion on one of these tractor terminals to cause a problem. I've even seen where the corrosion starts at a terminal and gets inside the wire insulation Share this post Link to post Share on other sites
Lagersolut 793 #7 Posted April 23, 2014 (edited) Something listed on the parts list as a " clutch module " # 15 , does anyone know exactly what this does ? http://www.partstree.com/parts/?lc=toro_consumer&mn=73450%2C+GT+Classic+Garden+Tractor%2C+2005+%28SN+250000001-250999999%29&dn=3353-258-_7440019-00017 Edited April 23, 2014 by Golds-Red Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,989 #8 Posted April 23, 2014 Started to upload the complete manual the detailed wiring diagram came from. The modules are explained in the Glossary now posted Garry Share this post Link to post Share on other sites
Lagersolut 793 #9 Posted May 4, 2014 Update: Finally found it , after weeks of chasing this intermittent problem, tearing the tractor apart only to have it start working just as I'm ready to chase wires etc ... took me right where I started - the neutral switch ....the switch itself was working - the plug connecting it to the wiring harness was bad .....for whatever reason the plug had a lot of slop in the connection even when it was locked together creating a dead spot ......cut it out and installed new plugs . This was not an easy find - thanks for the wiring diagrams Gary - .. really helped me narrow this down. Share this post Link to post Share on other sites
thehorse 221 #10 Posted May 11, 2014 I'm having the same problem currently! Share this post Link to post Share on other sites
