wheelhorse66 10 #1 Posted April 21, 2014 What kind of oil goes in a four speed tranny and how much Share this post Link to post Share on other sites
boovuc 1,090 #2 Posted April 21, 2014 You will get a lot of different opinions but generally, all you ever have to run in the rears of the 4 or 8 speed manual rears is a good quality 80w-90 gear oil. That's about it! I don't know what tractor you have so I can't comment on quantity. However, you can never get all the old gear oil out so whatever the manual says, it is going to be less. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,012 #3 Posted April 21, 2014 It should be in this chart Garry Share this post Link to post Share on other sites
wheelhorse66 10 #4 Posted April 21, 2014 Its a 1056 Share this post Link to post Share on other sites
wheelhorse66 10 #5 Posted April 21, 2014 Its a 1056 it won't let me download the chart Share this post Link to post Share on other sites
stevasaurus 23,619 #6 Posted April 21, 2014 (edited) It should have a fill hole plug on the side of the trans...about an 1" up from the bottom. Most are on the left side near the axle housing. Your trans should take about 1 1/2 qts. Fill through the shifter hole, or take off the seat and fill through one of the seat bolt holes...if you do not have a dip stick...easiest way to do this. Fill until oil starts to run out that fill hole. Boomshakalaka!!! Being in Virginia...I would use the 80/90 wt oil. Edited April 21, 2014 by stevasaurus Share this post Link to post Share on other sites
