dandan111 66 #1 Posted April 19, 2014 Is there a replacement seat I can get that will take my seat switch? Any links to a thread to help would be great. I have the seat with the long springs on the back. Think my tractor is a 1997. I have seen several toro seats on e-bay but I don't know what I need. Share this post Link to post Share on other sites
dandan111 66 #2 Posted April 19, 2014 (edited) image by Fad46962@yahoo.com, on Flickr Edited April 19, 2014 by dandan111 Share this post Link to post Share on other sites
doc724 925 #3 Posted April 19, 2014 I just went through this. I probably spent 3 hrs searching every site and there is NO seat that has that odd ball bolt pattern. My final solution was to get a seat that had a seat switch in it and I made two adapters from 1/4 inch thick by 1.5 inch steel bar stock. Drill and tap the adapters to fit up with the hole patterns on the existing seat mount and drill clearance holes in the the adapters to fit the new seat bolt pattern. Use the little plastic washers from the old seat to allow the bolt heads on the adapters clear the seat mount. If this does not make sense, send me a PM and I will take a few pix for you tomorrow. The only other way is to get an older style seat mount and there are dozens of seats which fit that bolt pattern. 1 Share this post Link to post Share on other sites
dandan111 66 #4 Posted April 20, 2014 I would rather not over ride my seat switch. 1 Share this post Link to post Share on other sites
Mower Man 9 #5 Posted April 14, 2018 Did anyone find a replacement Seat? I don't care if the seat switch is there or not. The bolt pattern is 6" wide and 8" deep. 92-6511 is the Toro Part number. The Michigan Seat Company in Jackson, MI made the seats for Toro. Share this post Link to post Share on other sites
953 nut 64,144 #6 Posted April 14, 2018 I had the same problem, found a seat that had the cut out slot for the seat switch but the nuts weren't in the correct place. I used four #14 sheet metal screws and lock washers to mount it and all is good. Share this post Link to post Share on other sites
Tankman 3,528 #7 Posted April 16, 2018 (edited) On 4/14/2018 at 5:57 AM, Mower Man said: Did anyone find a replacement Seat? I don't care if the seat switch is there or not. The bolt pattern is 6" wide and 8" deep. 92-6511 is the Toro Part number. The Michigan Seat Company in Jackson, MI made the seats for Toro. Tractor Supply has numerous steel pan seats on the shelf, reasonably priced. I used quite a few. Bolt patterns are universal, several patterns on each seat. Press nuts fitted, bolt on and you're all set to ride 'em cowboy. "This seat features a standard 5/16" thread for the mounting holes, and multiple mounting patterns: 6in. x 5in., 7.5in. x 3in., 7.5in. x 7in., 8.2in. x 5in., 8.5in. x 1.63in., 11.25in. x 11in." https://www.tractorsupply.com/tsc/product/black-talon-deluxe-high-back-steel-pan-seat?cm_vc=-10005 Edited April 16, 2018 by Tankman Share this post Link to post Share on other sites
TDF5G 2,073 #8 Posted April 20, 2018 On 4/19/2014 at 6:24 PM, doc724 said: I just went through this. I probably spent 3 hrs searching every site and there is NO seat that has that odd ball bolt pattern. My final solution was to get a seat that had a seat switch in it and I made two adapters from 1/4 inch thick by 1.5 inch steel bar stock. Drill and tap the adapters to fit up with the hole patterns on the existing seat mount and drill clearance holes in the the adapters to fit the new seat bolt pattern. Use the little plastic washers from the old seat to allow the bolt heads on the adapters clear the seat mount. If this does not make sense, send me a PM and I will take a few pix for you tomorrow. The only other way is to get an older style seat mount and there are dozens of seats which fit that bolt pattern. I went through this about a year ago also, trying to track down a seat for my Dad's 314-8. I could not find a seat with the bolt pattern. We lucked out when a used one popped up on ebay so I grabbed it. 1 Share this post Link to post Share on other sites
