SethL1984 38 #1 Posted April 16, 2014 Will an 07-36TL01 hook right up to a 400 series? Share this post Link to post Share on other sites
groundhog47 441 #2 Posted April 16, 2014 (edited) That should be a 1983 tiller, what year model is the 400? These units are what was sown as attachment tillers for the years that followed. My guess is each mod last two #'s was an upgrade/modification (07-36TL01> 81- 83, 07-36TL02> 83 - 86; 07-36TL03> 87,88, 89; 07-36TL04> 90,91; 07-36TL05>,92; 79370> 93) I know this is no direct answer, on the 01-05 tiller attach bracket appears same and mules appear same. You could try and find what does fit and check difference. Most all tillers throughout years, except 3 point and self powered attach near same , but have different mule types (safety guards, tension pull direction, pulley material type, lift method, ect). I would say if you can hook it up to back axel hitch or how ever, the rest is mule or belt arrangement/length. If you've not perused through: Manuals>implements>ground engaging>pg 7 there are .pdf downloads and operator manuals that may help Edited April 16, 2014 by groundhog47 Share this post Link to post Share on other sites
daveoman1966 3,881 #3 Posted April 16, 2014 YES. There are 4 or 5 idler pulley bracket configurations but all hook-up in the mid tach-o-matic hitch. Share this post Link to post Share on other sites
