Cutlas3391 776 #1 Posted April 15, 2014 Hey guys I have this Week Horse D 3pt Finish Mower deck I'm considering selling but don't have any idea what's it worth? It's very solid and all the spindles work as they should. I never see too many for sale. Feedback would be great thanks Sent from my LG-D800 using Tapatalk Share this post Link to post Share on other sites
pfrederi 19,940 #2 Posted April 15, 2014 I have had one for few years. They are a quality unit...made by woods share a lot of parts with the Woods L59 series widely used as belly mounts on small farm tractors. To come up with a reasonable value some questions. Do you have the other half of the PTO? The top link should be a Cat 0 adjustable type not a fixed bar. Do you have the leveling/check chains? Blades look a bit worn. Any rust throughs? Share this post Link to post Share on other sites
Cutlas3391 776 #3 Posted April 15, 2014 No rust holes very solid. Unfortunately u see what you get. Sent from my LG-D800 using Tapatalk Share this post Link to post Share on other sites
ericj 1,579 #4 Posted April 15, 2014 it's junk, i'll just come pick it up lol. seriously they generally range from $300.00 and up i would love to find a usable because the 1 i have needs to much work if it is usable at all. but i have to many irons in the fire right now and no money if you know what i mean. good luck eric j 1 Share this post Link to post Share on other sites
pfrederi 19,940 #5 Posted April 15, 2014 (edited) No rust holes very solid. Unfortunately u see what you get. Sent from my LG-D800 using Tapatalk Not to be picky but how do you know if the spindles are good if there is no PTO shaft to run it???? The PTO shaft is another hard to find item... I paid $300 for mine but it had the complete PTO shaft. Then i spent more on a top link, I do not have any pics of my rear mount on the D200 but here is a L59 on my Case VAC..shell and spindles are same as the WH version Edited April 15, 2014 by pfrederi 1 Share this post Link to post Share on other sites
Cutlas3391 776 #6 Posted April 15, 2014 Not to be picky but how do you know if the spindles are good if there is no PTO shaft to run it???? The PTO shaft is another hard to find item... I paid $300 for mine but it had the complete PTO shaft. Then i spent more on a top link, I do not have any pics of my rear mount on the D200 but here is a L59 on my Case VAC..shell and spindles are same as the WH version Honestly I just flipped it over and all three spindles move freely by hand. This deck is more then a trip hazard lol Sent from my LG-D800 using Tapatalk Share this post Link to post Share on other sites
546cowboy 302 #7 Posted April 17, 2014 Quite a while back when I was doing quite a bit of fabricating some ideas with stuff I had laying around I built a couple trail mowers. The first one I did had a Cub 42" deck and it worked OK. The second one I did, and still have is a 60" home made deck. I have a pasture that used to take me 4+ hours to mow with the an old Cub with a 42" deck I had then. Well let me tell you what that became a 1/2 hour job when I put both of those trail mowers behind behind that old Cub. That was 42"+42"+60"= 12 feet, well slightly less with the overlap. They did each have there own engines so I never got bogged down unless I let it get a foot or more high. The 60" one I built has never bogged down and will go pretty much anywhere. Here are some pictures. 1 Share this post Link to post Share on other sites
bitten 134 #8 Posted April 17, 2014 Would the PTO from a tiller work on this? Are the baffles supposed to be like this? Share this post Link to post Share on other sites
