curtis20
mounted 8hp briggs
curtis20
I have a workhorse 700 I just got with a 8 hp Briggs pull start on it. As I was working on it I noticed that only two motor mounting bolts were on because the way the motor sits on the frame it only matches up with 2 holes. So I think maybe I'll put a different motor on, but all the other motors I have looked at have the same spread on their bolts, so looks like no matter what I do I can only mount a motor on with 2 bolts. Will this be a problem? Does anyone else have this setup on theirs?
gwest_ca
Manual
Garry
KATO
Have you got the motor plate ?? Check the manual that Gary linked. :handgestures-thumbupright:
curtis20
Thanks
