rustyoldjunk 127 #1 Posted April 14, 2014 Of over a dozen WH tractors thru here lately,it seems the majority has one or both hubs worn and loose,Including a low hr C161 that never seems to have worked hard. I guess I never realized the hub issues were this bad. The one that really concerns me at this point is the C161. I think I will try to find a set of later heavy duty twin set screw hubs for it....and hope that they are both good when I put them on.. Share this post Link to post Share on other sites
Lane Ranger 12,161 #2 Posted April 14, 2014 The only time I see a loose hub on a Wheel Horse is one covered in grease from a leaky oil seal. The two bolt hubs do keep the hub from wearing better but I think that a lot of bad oil seals is the prime culprit Jim! 1 Share this post Link to post Share on other sites
C-101plowerpower 1,606 #3 Posted April 14, 2014 could also be that someone put the wrong hubs on, one of my hubs was always coming off, turns out someone put a 1 1/8 hub on a 1inch axle Koen Share this post Link to post Share on other sites
