DAVE L 31 #1 Posted April 12, 2014 (edited) I started this project a few years ago but was held up until now. In the process, I can't find a few parts. They may show up as I keep digging. I cant find the brake lock, but am wondering if one from a Raider 10 is the same.Also still searching for the clutch rod. Is there anything else that will work? The clutch rod pivot arm is also hiding on me. Any help would be great This is for the mid 60's Lawn ranger L-155. Thanks, Dave Edited April 12, 2014 by DAVE L Share this post Link to post Share on other sites
groundhog47 447 #2 Posted April 12, 2014 Dave, know you are looking for parts, but this manual, click on link and download, may help with part numbers and all: You can cross reference on asite using Toro Consumer and find diff models with same part numbers. Example site:http://www.smallenginepartswarehouse.com/p/toro-parts?aribrand=TO. Put in riding products in select box, pick 1965 year, and then find your LR, then select group it falls under. Next take your part number over to right side and enter. When it comes up, at right end says "select model". That will give you a list of models part in question will fit. 1 Share this post Link to post Share on other sites
DAVE L 31 #3 Posted April 12, 2014 Thanks Groundhog47! Share this post Link to post Share on other sites
DAVE L 31 #4 Posted April 18, 2014 Found the clutch rod pivot arm on ebay, Groundhog47 had good advice. Thanks Share this post Link to post Share on other sites
