GlenPettit 1,718 #1 Posted April 11, 2014 (edited) Saw this on another site, a nice 'better-idea' to control plowing depth. Edited April 11, 2014 by GlenPettit 2 Share this post Link to post Share on other sites
C-101plowerpower 1,606 #2 Posted April 11, 2014 Saw this on another site, a nice 'better-idea' to control plowing depth. pretty smart idea, i like it although i'd make it adjustable Koen 2 Share this post Link to post Share on other sites
leeave96 490 #3 Posted April 11, 2014 That's a nice addition. I've had pretty good luck in maintaining the plow depth by adjusting the angle of the plow point, but on the other side of it, I've broken a lift cable too - probably from trying to hold a depth with it as opposed to the plow floating to a specific depth. If the wheel gives you slack in the lift cable - that removes a lot of stress. Thanks for the post. Share this post Link to post Share on other sites
AMC RULES 37,232 #4 Posted April 11, 2014 pretty smart idea, i like it although i'd make it adjustable Koen Click on the pict to enlarge...wheel is adjustable. 1 Share this post Link to post Share on other sites
Lane Ranger 11,626 #5 Posted April 11, 2014 Yep - a good idea! Share this post Link to post Share on other sites
C-101plowerpower 1,606 #6 Posted April 11, 2014 Click on the pict to enlarge...wheel is adjustable. thanks craig, hadn't seen it before, maybe i need new glasses Koen 1 Share this post Link to post Share on other sites
shorts 182 #7 Posted April 11, 2014 Interesting concept, I just wonder how effective it would be with the slotted adjustment and air tire knowing that the plow exerts a tremendous amount of down pressure until the plow point and landshare are level in the bottom of the furrow Share this post Link to post Share on other sites
KC9KAS 4,744 #8 Posted April 12, 2014 You are correct, the gauge wheel is adjustable. It is my plow & photos. 1 Share this post Link to post Share on other sites
Whmaverick 54 #9 Posted April 20, 2014 Properly adjust the suck. And no gauge wheel is necessary. Lots of instruction on plow adjustment on the Internet. Share this post Link to post Share on other sites
squonk 44,600 #10 Posted April 20, 2014 You are correct, the gauge wheel is adjustable. It is my plow & photos. Have you tried it out yet? How well does it work? I think what happens a lot of times is that guys make there cables too short. They raise the plow way off the ground when traveling but then there isn't enough cable for the plow to "move" as it's plowing. then catch a root or something and it can really stress the cable. I like the wheel idea. I might copy that but do the bracket a different way to hang a suitcase weight off of it if needed too. Share this post Link to post Share on other sites
KC9KAS 4,744 #11 Posted April 20, 2014 Have you tried it out yet? How well does it work? I think what happens a lot of times is that guys make there cables too short. They raise the plow way off the ground when traveling but then there isn't enough cable for the plow to "move" as it's plowing. then catch a root or something and it can really stress the cable. I like the wheel idea. I might copy that but do the bracket a different way to hang a suitcase weight off of it if needed too. Haven't tried it yet. The plow has a sleeve hitch and I do not have a GT with a sleeve hitch. I am looking for a slot to sleeve adapter, or I will have to build one. Share this post Link to post Share on other sites
cumminscook 60 #12 Posted April 22, 2014 (edited) I have bin playing around with mine its cutting down 7-8" its working good Edited April 22, 2014 by cumminscook Share this post Link to post Share on other sites
