music100 10 #1 Posted April 10, 2014 Hi guys, got my rear tires mounted and filled. Now the front ones, looking at it straight on it looks a little spraddle legged if you know what I mean. What type of bearings do they have in the front wheels? Whatever is there is worn out but hopefully the spindles aren't bent. Also a new switch and seat from the bay. Still have to go back and do some wiring clean up. Going to be slow but quite a machine. A 414-8 BTW. Thanks, John Share this post Link to post Share on other sites
Kelly 1,033 #2 Posted April 12, 2014 Ball bearing in the front, you can buy cheap replacements at TSC or other hardware stores, they are 1 3/8" x 3/4" with a flange or lip on one side, they run about $3 each I like the full sealed machined steel bearings, cost a bit more about $10 each they can be had at most mower shops or ebay Share this post Link to post Share on other sites
music100 10 #3 Posted April 12, 2014 thanks for the reply my friend, will pick some up this coming week. Along with some tires and hopefully rear wheel weights. Thanks, John Share this post Link to post Share on other sites
