Wishin4a416 2,270 #1 Posted April 9, 2014 The Kohler rebuild kit that I got from ebay says it is mandatory to replace the aluminum plunger with the steel one. Does anyone know why this is? Share this post Link to post Share on other sites
rmaynard 16,683 #2 Posted April 9, 2014 The aluminum one wears too quickly and changes the gap. Share this post Link to post Share on other sites
Wishin4a416 2,270 #3 Posted April 9, 2014 Thanks Bob!! Share this post Link to post Share on other sites
Fordiesel69 271 #4 Posted April 9, 2014 I personally would not replace it. The cam lobe cam wear more. If you do annual maint, which is very important, there is no problem making a .001-.003 adjustment to the points. I know this sucks, but it is better than wearing out the cam. Lastly, any aftermarket points that are missing the words Echlin, or Kohler, and absolute trash. Toss them out. Also the Chinese no name spark plugs that come in the kit are also trash. 2 Share this post Link to post Share on other sites
shorts 182 #5 Posted April 10, 2014 I agree, the steel pushrod will wear away the cam faster to the demise of an engine that won't wear out fast enough to require replacement with a new engine. if you continue to use the aluminum pushrod you will need toreadjust or at least check the points on an annual basis. Share this post Link to post Share on other sites
buckrancher 2,695 #6 Posted April 10, 2014 I will not use the steel point push rods in any of the motors I rebuild Brian Share this post Link to post Share on other sites
SousaKerry 503 #7 Posted April 10, 2014 Ok so has anyone ever made one from bronze and tried it? Share this post Link to post Share on other sites
buckrancher 2,695 #8 Posted April 10, 2014 if the alum push rods wear out so fast how come sixty year old motors are still running good with the original one in them change your oil once a year with a good grade 30wt and yours will last that long too Brian 4 Share this post Link to post Share on other sites
oldlineman 1,586 #9 Posted April 10, 2014 I have a 1979 c-101-8 and a 1989 414-8 never had to adjust the points on ether one. 414 has 950 hours the c-101 how knows guessing 2000 plus change the oil and no troubles.Never had the heads off of ether engine.They just need some regular maintenance. Share this post Link to post Share on other sites
rmaynard 16,683 #10 Posted April 10, 2014 ...change your oil once a year with a good grade 30wt and yours will last that long too Brian I guess the same thing could be said for the steel ones too. 3 Share this post Link to post Share on other sites
oaktown1987 82 #11 Posted April 14, 2014 In ill 30wt getting hard to find Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
rmaynard 16,683 #12 Posted April 14, 2014 In ill 30wt getting hard to find Sent from my iPhone using Tapatalk Straight 30W is available at Walmart, NAPA auto parts, and Advance auto parts if you have any of those stores. Briggs & Stratton still packages 30W in 2 qt. bottles and sells it at most TSC stores, and all John Deere dealers have it on their shelves in the famous green and yellow bottles. Share this post Link to post Share on other sites
oaktown1987 82 #13 Posted April 18, 2014 Only sae 30 wal mart carries is super tech. Won't run that that the auto parts stores don't have sae weight napa has napa brand sae 30 which is valvoline but finally they have penzoil Sent from my iPhone using Tapatalk I ain't using briggs oil tsc has castrol in sae 30 which is 30 miles away don't get over too much Sent from my iPhone using Tapatalk John Deere which I use work at the sae 30 is for diesel Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,834 #14 Posted April 18, 2014 Many of the 30 weight oils I see now are thought to be a diesel oil. If you read the fine print on the bottle you will see it covers two types of older engines. CC, CE or CD etc. The first letter C is for Compression ignition engines meaning diesel. SC, SE or SD etc. The first letter S is for Spark ignition engines meaning gasoline. (Today's latest gasoline multigrade is up to about class SM or SN) Garry Share this post Link to post Share on other sites
gwgdog66 23 #15 Posted August 12, 2014 Have any of you had one warp and get stuck? The stuck plunger broke when we were trying to pull it out to replace it. It's the aluminum plunger. Has anyone been successful drilling the old one out? Share this post Link to post Share on other sites
Coadster32 793 #16 Posted August 12, 2014 I guess the same thing could be said for the steel ones too. I see a pattern here..normal maintenance being way more important than the pushrod material. Maybe the points gap stays correct for longer periods of time with a metal pushrod, at the chance of messing up the lobe. However...when the aluminum one does wear out, where does the aluminum go? Some of it comes out in the oil during changes yes, but prob. not all of it. (Should check gap once a year anyhow). Share this post Link to post Share on other sites
Coadster32 793 #17 Posted August 12, 2014 Many of the 30 weight oils I see now are thought to be a diesel oil. If you read the fine print on the bottle you will see it covers two types of older engines. CC, CE or CD etc. The first letter C is for Compression ignition engines meaning diesel. SC, SE or SD etc. The first letter S is for Spark ignition engines meaning gasoline. (Today's latest gasoline multigrade is up to about class SM or SN) Garry Didn't know that. Pretty cool. I'd assume the second letter is grade quality? N being better than M. Share this post Link to post Share on other sites
buckrancher 2,695 #18 Posted August 12, 2014 pennsoil SAE30 at TSC 1 Share this post Link to post Share on other sites
specialwheelhorse 174 #19 Posted August 12, 2014 Have used in a pinch hardened steel dowel pin of proper length And polishing cam end slightly rounded and polished like a mirror. Can't even remember what engine it was in. Remember like materials wear and weld very easy. Unlikes usually do well in a wear situation. 1 Share this post Link to post Share on other sites
520HC 208 #20 Posted August 12, 2014 Just a thought, Kohler has 30wt oil also. Share this post Link to post Share on other sites
DrabHorse 2 #21 Posted August 13, 2014 (edited) I know this isnt an oil topic, but I wanted to add that Shell Rotella T1 30W is a good choice also. I have bought it at walmart, although it will be on sale sometimes at the auto stores. It may not be stocked at all walmarts, my local dosen't have it, but the next closest one does. Edited August 13, 2014 by DrabHorse Share this post Link to post Share on other sites
zanepetty 117 #22 Posted January 30, 2015 (edited) So if the push rod gets a little short you can't readjust the points to compensate? Edited January 30, 2015 by zanepetty Share this post Link to post Share on other sites
Wishin4a416 2,270 #23 Posted January 30, 2015 Wow, my old thread. I put the original rod back in. And I use 30 Wt. Rotella from TSC. And yes Zane. Share this post Link to post Share on other sites
zanepetty 117 #24 Posted January 31, 2015 Ohkay thanks. Just wondering if that would make the points gap too short. 👠Share this post Link to post Share on other sites
buckrancher 2,695 #25 Posted January 31, 2015 Ohkay thanks. Just wondering if that would make the points gap too short. NO it just means the screwdriver blade may not fit in the point gap adjustment slot on the ponits Brian Share this post Link to post Share on other sites
