dschepis@hotmail.com 0 #1 Posted April 6, 2014 My 310-8 doesn't stop running when the key is switched off. I throttle her all the way down and turn off the switch. She'll backfire out the muffler but keep running until I lift the hood and jerk the plug wire ( 10 HP Kohler). Looks like the seat switch has been bypassed as has the clutch switch. Tractor is new to me but has seen better days. Just got the old girl running after cleaning out the fuel tank, new lines, inline filter, etc. Should I just put a battery disconnector on to stop the engine? Are replacement ignition switches available? How does the kill wire work? Thanks Don Schepis Share this post Link to post Share on other sites
953 nut 60,682 #2 Posted April 7, 2014 (edited) You should have a Magnum Kohler on the 310, if so the magnito will be grounded out by the ignition switch when in the off position, make sure the wire hasn't broken off, if so that would be the problem. If that isn't the problem others may have an idea. Edited April 7, 2014 by 953 nut Share this post Link to post Share on other sites
wheeledhorseman 579 #3 Posted April 7, 2014 I've found the ignition switches can indeed become faulty in repect to failing to shut down an engine with magneto ignition. So if you've checked the wiring and that the switch body itself has a good earth and it's still not switching the engine off, it can be the switch itself. From the way you describe it backfiring it certainly sounds like an intermittent conection in the kill wire circuit which can be caused inside the switch as well as the wiring to it. Hope this helps you. Andy Share this post Link to post Share on other sites
KATO 115 #4 Posted April 7, 2014 Welcome to And yes you should be able to get a new switch if it turns out that is whats wrong... here a link to Toros parts viewer, just select your year/model number http://www.toro.com/en-ca/parts/Pages/PartsLookupResults.aspx?searchTerm=310-8&BasicSearchFilter=equipment And heres a link to a price assuming its the right year i used ???(1988) http://www.jackssmallengines.com/searchresults.cfm?cx=008737122150761418589:c24nnqwh7co&cof=FORID:11&q=111215 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,560 #5 Posted April 7, 2014 Looks like Jacks has a mistake there. Switch is too many $. Suspect the part number should be 430128 or Stens # 430-128. Garry Share this post Link to post Share on other sites
dschepis@hotmail.com 0 #6 Posted April 7, 2014 Gentlemen, Thank you all for your input and information. I do appreciate the help. Your explanations make sense and I think I understand the problem. At least now I have a direction to go. Some of the various terminals are all corroded up and I suspect some of the earths ( THX Andy ) need to be re-established. If I can get her through plowing up a vegetable garden, then I can garage her all summer for a complete tear down. Thank You All Again, Don Schepis Share this post Link to post Share on other sites
Save Old Iron 1,571 #7 Posted April 8, 2014 To stop the engine, the M terminal of the ignition switch grounds out the WHITE wire in the harness leading to the magneto. When the white wire is grounded, the magneto cannot produce spark and the engine either stops or cannot be started. Another wire may lead from the seat switch to ground the magneto if the operators leaves the seat while the PTO is engaged. Share this post Link to post Share on other sites
dschepis@hotmail.com 0 #8 Posted April 9, 2014 Saving Old Iron, Thank you, According to the Toro partsfinder that KATO linked me to, My model and serial number is for a 1991 machine. It does have the Kohler magnum 10 engine. Based on the schematic you posted, I get no continuity to ground between the white wire terminal and ground terminal on back of the switch when the key is in the off position ( only difference is my switch has 5 terminals instead of the 6 illustrated). This supports the suggestions that the magneto isn't grounding out to kill the engine. Now I understand memories of touching the metal tab to the plug on old engines to turn them off. Well, I learned something. Thank You all. Now to chase down a switch Share this post Link to post Share on other sites
Save Old Iron 1,571 #9 Posted April 9, 2014 The 6th missing terminal may be the ground terminal. On a dash panel which is plastic or ungrounded. a jumper wire from the G terminal to chassis will assure the ignition switch can ground the magneto when needed. You may want to check for continuity between the switch body and chassis ground. If for some reason the body of your ignition switch is no longer grounded, this would cause your symptom regarding the ignition not being killed. . Share this post Link to post Share on other sites
wheeledhorseman 579 #10 Posted April 9, 2014 As chance would have it I was working on the lower dash panel of my 316 yesterday. Although a 316 doesn't need an earth for the ignition switch these panels seem to have been made in a 'universal' way by masking off the area round the hole for the switch with a bit of tape before the panel was painted. Obviously this helps the serrated washer that sits between the switch and the panel make a good earth connection (when a kill circuit for magneto is needed) but the area had become rusty over the years and I couldn't help thinking that the earthing would also rely on the screws that hold the panel in place as well. Not an especially clever design. Andy Share this post Link to post Share on other sites
dschepis@hotmail.com 0 #11 Posted April 10, 2014 Andy, I agree on the clever comment. My dash panel is rusted and the area under the bolt heads is painted and is now rusted. Per save old iron's comment I could run a ground lead off the terminal to the chassis ground and probably will with a new switch. But based on what I learned here, my switch is crapped out and no longer makes connection for the magneto lead to ground in the off position. I've been working on a sleeve hitch for my moldboard plow this week and finished welding it up this afternoon. I think I can run a temporary kill switch so that I can get the garden plowed this weekend. Then I'll start on a more permanent repair. I was able to temporarily rig the plow yesterday and turned over a few rows. I'm really starting to be impressed with the pulling power this little old tractor has. Thanks, Don Schepis Share this post Link to post Share on other sites
Save Old Iron 1,571 #12 Posted April 10, 2014 Don, just to be clear, do not run a ground wire directly to the M terminal on the switch. If your switch has a G terminal then yes, run a wire from the G terminal to a good chassis ground. If the G terminal is absent, make sure the metal panel supporting the ignition switch is grounded and the "neck" and fastening nut of the ignition switch is in contact with the grounded metal panel. If you run a wire from the M terminal to the chassis, the magneto will always be grounded and the engine will not fire. Share this post Link to post Share on other sites
dschepis@hotmail.com 0 #13 Posted April 11, 2014 Save Old Iron, Thank you. I understand. I picked up a little 20 amp toggle switch today that I was going to patch in between M terminal and ground. I am only using it as a temporary kill switch. Hopefully I'll get my plowing done this weekend and then I won't need the tractor for a while. I bought it specifically to turn over the sod for a big garden patch and then it will have a snow blade on it for winter driveway use and other hauling chores. Thanks, Don Schepis Share this post Link to post Share on other sites
bowtieguy 334 #14 Posted April 11, 2014 Don...send me a pm if you need a harrow or a snow blade for your horse...your 310 is a HORSE for sure Share this post Link to post Share on other sites
dschepis@hotmail.com 0 #15 Posted April 11, 2014 Not sure how to PM, I have a snow blade and an 8 point cultivator, but I'd be interested in a correctly sized disc harrow. Thanks, Don Schepis Share this post Link to post Share on other sites
2bcross3 1 #16 Posted April 27, 2014 Thank you for the topic replies. Mine started doing the same thing today. Still ran after turning the ignition switch to off. I did find out if I pressed in hard on the key it would shut off. Pulled the ignition switch and found the "A" terminal all corroded. I'll be cleaning that up and checking for good continuity on the "M" wire and good ground. Tapatalking from my galaxy Share this post Link to post Share on other sites
