music100
No numbers
music100
Wonder what you folks do when the numbers a missing on these tractors? The tractor number itself is there -3114K803, but none on the engine or the deck. It seems they are usually needed for parts and such. The only thing on the engine is Magnum 14, no other tags or anything. The deck just shows the belt routing. Doesn't need anything now but maybe later so now what? Also how to decipher the tractor no.? Thanks, John
WH nut
Pictures is the first thing. It would take me awhile to cipher the numbers you posted. Im sure someone while chime in before I figure it out
daveoman1966
Go here to see the accessories for your tractor.
http://www.toro.com/en-us/parts/Pages/PartsDetails.aspx?mybeid=2530&serialNumber=None&modelNumber=31-14K803&searchTerm=9lzIRv+p5zeacc1diZ+XD4h2N9AzTFBSE8nH6mHBaIfq86FAGmK6tXL84l1P/N/GBtDCqyPvCjM=&defaultTab=parts
31= tractor
14= engine hp
K= Kohler
8= 8 speed
01=  model year progression
31-14K801 1986 414-8 Garden Tractor
Edited by daveoman1966
WH nut
31= tractor
14= engine hp
K= Kohler
8= 8 speed
See
KC9KAS
His number is 3114K803, so it is a 1988 414-8
Edited by KC9KAS
music100
Thanks a lot for the info guys, sheds some light. Don't know that the deck came on this machine originally, the fellow I bought it from seemed to buy juckers and get them running. Wiring looks bad but it runs, will have to figure that out after the tires get changed. Just bought a switch off of the bay, we'll see how it goes. John
WH nut
It could have been any number of decks but I would guess either a 42 or 48in. Any deck from about 73 up will fit it as long as its attachamatic
Kelly
Be sure you bought a switch for the magnum engine, they are magneto ign. not batt. ign. and they do not interchange
