wheeledhorseman 579 #26 Posted April 13, 2014 Gotta be pleased with that hood Ian, I would be! Andy Share this post Link to post Share on other sites
Stigian 1,235 #27 Posted April 14, 2014 Looking good Ian been watching your three point linkage on you tube I'm going to copy your idea if you don't mind ! Cheers James Thanks James, your more than welcome to copy my 3 point idea.. Just don't forget the photos Gotta be pleased with that hood Ian, I would be! Andy Thanks Andy, yes I am pleased with how the hood is turning out... I found a few more small holes in it today, more patches coming up..... But not today.. Today I've been tackling some thicker metal, no not the seat pan but the fender pan Here it is as arrived! A bit of straightening soon made the back a lot less flat and a lot more like the shape it should be. A dig in the pile of metal off cuts unearthed these two bits that were left over from making the 6x6 fenders.. Hhmm, this looks like it should work. Ok the line is not quite original but unless your a serious spotter with a tape measure no one will notice the difference To fill the gap between the two "er... bits where the lines get lower", a dig under the bench found this off cut... Don't worry Mark, your corners are still safely stashed away Quite a while later... The rusted away lines are back While I was under the bench I also found this long forgotten 300 series side cover. Trimmed down a bit. See these rusty holes? Gone!! Almost.. The patch just needs a little tweak then it's ready to be welded in.. If all goes well I might even get the fender pan finished tomorrow!! Share this post Link to post Share on other sites
HorseFixer 2,013 #28 Posted April 14, 2014 Stig yer the Stig of all Stig's and being your doing such a great job, I think its time for me to Pour a Morgan and fully enjoy yer work! ~Duke 1 Share this post Link to post Share on other sites
woodchuckfarmer 333 #29 Posted April 16, 2014 You may know this already, get some copper bar stock and clamp it under your weld joint. This will stop the melt threw. It takes the heat away faster. Very good repair......Wayne 1 Share this post Link to post Share on other sites
"D"- Man 827 #30 Posted April 18, 2014 Impressive! The only difference between what you're doing, and thee impossible, is, thee impossible is just a little bit harder. Mark. 1 Share this post Link to post Share on other sites
Stigian 1,235 #31 Posted April 19, 2014 Stig yer the Stig of all Stig's and being your doing such a great job, I think its time for me to Pour a Morgan and fully enjoy yer work! ~Duke Thanks Duke, but make mine a Lambs Navy You may know this already, get some copper bar stock and clamp it under your weld joint. This will stop the melt threw. It takes the heat away faster. Very good repair......Wayne Thanks Wayne, I do use that trick, but I use a slab of brass instead... Some say that weld will stick to brass, I've never had a problem with it Impressive! The only difference between what you're doing, and thee impossible, is, thee impossible is just a little bit harder. Mark. I like that Thanks Mark, that's a great compliment. Well, the fender pan didn't quite get finished as I said above.. It's not finished now but very close To hold the above big plate in place for welding and to stop it dropping through the hole, I welded a few tabs on... Like so. I forgot to take any photo's of that plate being welded on, but on the same day I discovered I had another rust problem!! I was wondering why my tobacco was drying out so fast Anyway, now for something pressing.. Making the missing indent bit that is used to bolt the fender pan down.. See what I mean by pressing I must of made about 8 of these, trying different thicknesses of metal, different strengths, different object to press them into, and finally different ways to cut the steel before pressing... Can you spot which one is the old indent bolt hole mount thingy? The trick to making your repairs look better than they are on camera is to give the metal a quick buzz over with a DA sander first A close up of the indent hole mount thingy. The underside still needs a bit of a tidy up, but it's not looking too bad. 2 Share this post Link to post Share on other sites
diggerjames 64 #32 Posted April 19, 2014 Not looking to bad at all mate keep it up I'm just starting on the tin work my self on B-80. It's not as bad as that tho Ian 1 Share this post Link to post Share on other sites
HorseFixer 2,013 #33 Posted April 19, 2014 (edited) Posted Today, 01:00 PM Stig yer the Stig of all Stig's and being your doing such a great job, I think its time for me to Pour a Morgan and fully enjoy yer work! ~Duke Thanks Duke, but make mine a Lambs Navy Stig I didn't know what Lambs Navy was So I googled it. And posted their add above Gee........ I guess I see what you mean... I Guess I will be switching brands of Rum! Besides I'm a Navy man myself anyways! ~Duke Edited April 19, 2014 by HorseFixer Share this post Link to post Share on other sites
Stigian 1,235 #34 Posted May 3, 2014 Not looking to bad at all mate keep it up I'm just starting on the tin work my self on B-80. It's not as bad as that tho Ian Thanks James, good luck with your B-80's tins. Posted Today, 01:00 PM Thanks Duke, but make mine a Lambs Navy Stig I didn't know what Lambs Navy was So I googled it. And posted their add above Gee........ I guess I see what you mean... I Guess I will be switching brands of Rum! Besides I'm a Navy man myself anyways! ~Duke I think your quite like Navy rum Duke, it is nice stuff A small update for you chaps.. The fender pan is just about done, just a little tidying around the new mounting hole thingy to do. The hood has had an extra repair patch where I found a few more rust holes.. I was going to patch up 3 rust holes on the top of the hood, but I was able to get away with filling the holes with weld,, Kinda blend in don't they A bit closer with the flash turned off you can see they still need a little grinding down. Work on the seat pan has been started.. A cardboard template. And some galvanized steel to make the repairs from... A big thank you to Pete for grabbing this and other bit's of steel before they went into a skip The first attempt didn't go to well and the angles were way off!! Like any good engineer I blamed the cardboard template, and made another template from masking tape This time the repair patch fit's a lot better, it just needs a little trim and shaping to get it spot on.. The seat pan is not quite finished yet, but for now I will leave these couple of photos here 1 Share this post Link to post Share on other sites
Digger 66 3,488 #35 Posted May 3, 2014 (edited) I quite like the look, if it were mine I'd just oil it once in a while to stop the rust getting any worse X - 2 ! Edited May 3, 2014 by Digger 66 Share this post Link to post Share on other sites
19richie66 17,770 #36 Posted May 4, 2014 Looks great Ian.I have the pitting problem with the hood on my tractor. High build primer? I'll keep watching.Thanks for the pics and the write up,Richie Share this post Link to post Share on other sites
AMC RULES 37,251 #37 Posted May 4, 2014 When will the tobacco tin repair thread start. Share this post Link to post Share on other sites
C-101plowerpower 1,606 #38 Posted May 4, 2014 When will the tobacco tin repair thread start. atleast we now know where the idea for the clock pictures came from, he was smoking rust flakes Koen 2 Share this post Link to post Share on other sites
AMC RULES 37,251 #39 Posted May 4, 2014 ...or something he needed to dry out. Share this post Link to post Share on other sites
Stigian 1,235 #40 Posted May 10, 2014 Looks great Ian.I have the pitting problem with the hood on my tractor. High build primer? I'll keep watching.Thanks for the pics and the write up,Richie Thanks Richie. Paint is not my area of expertize, you would be better asking some of the other chaps about that.. I'm not painting these panels only repairing the rust and holes. When will the tobacco tin repair thread start. A bit late for that Craig.. It's amazing what a bit of filler can hide Ok, it might not be the same tin base I filled the base of this one years ago, the idea being to do some carving... after 8 years not carving has happened atleast we now know where the idea for the clock pictures came from, he was smoking rust flakes Koen Ahhh.. That's why my roll up had a slight metallic taste ...or something he needed to dry out. Drying the banana skins is the easy part.. I'm struggling with getting the papers around them A little update for you chaps.. The big patches have been fully welded up. And a small hole at the front got the same treatment, I just need to trim it to size I also found another small hole on the right side of the seat base.. Which turned into a bigger hole. For some reason I forgot to take any photo's of that patch being welded on, so here's one of the big patches marked out for trimming to size. And that chaps is the seat pan just about done.. as ever there is a little grinding of welds inside to be done, but that's all. Here's the first part of the repair videos.. Enjoy Share this post Link to post Share on other sites
Olratlr 25 #41 Posted June 1, 2014 Ell of a job you are doing Thanks for sharing. Share this post Link to post Share on other sites
