slammer302 2,156 #1 Posted April 5, 2014 I need the dimensions of a cast iron front wheel weight I'm going to try to make a set Share this post Link to post Share on other sites
Tankman 3,523 #2 Posted April 5, 2014 I need the dimensions of a cast iron front wheel weight I'm going to try to make a set What size wheel? Share this post Link to post Share on other sites
slammer302 2,156 #3 Posted April 5, 2014 8inch its for a commando 8 Share this post Link to post Share on other sites
Tankman 3,523 #4 Posted April 5, 2014 (edited) 8inch its for a commando 8 How much weight do you want / require? The easiest "adder" would be fill the tires. I'll measure a rim tomorrow. There are numerous designs possible depending what machinery you have available; i.e.: turn down some cast barbell weights and add some bolt holds. Edited April 5, 2014 by Tankman Share this post Link to post Share on other sites
slammer302 2,156 #5 Posted April 5, 2014 That would be easier but in at work and I have s CNC plaze and sum 1" steel that's dieing to be cut Share this post Link to post Share on other sites
KC9KAS 4,744 #6 Posted April 5, 2014 That would be easier but in at work and I have s CNC plaze and sum 1" steel that's dieing to be cut You lucky dog! Share this post Link to post Share on other sites
