3Six 30 #1 Posted March 30, 2014 (edited) Hi Noticed what appeared to be a mounting plate/surface on the side of an MV16 twin engine. So, I will pose the question, is the engine convertible from vertical to horizontal shaft? If so, what are the details for the conversion? Thanks Ed Edited March 30, 2014 by 3Six Share this post Link to post Share on other sites
Desko 636 #2 Posted March 30, 2014 Pictures will better explain. Vertical shafts can be converted to horizontal shafts depending on the motor oil pressure or splash lube Share this post Link to post Share on other sites
3Six 30 #3 Posted March 30, 2014 Pressure lubricated with oil filter Share this post Link to post Share on other sites
Desko 636 #4 Posted March 30, 2014 It probably won't work being its pressure lubricated un less to find a similar motor with crank pump sump cover etc. Share this post Link to post Share on other sites
