Cam-c121 6 #1 Posted March 24, 2014 Hello gents have been looking at some wheel weights but most of the bolts are missing it comes with 2 to be infact are these hard to find or is it something I could go and get off the shelf at somewhere like b&q thanks in advance Cameron Share this post Link to post Share on other sites
groundhog47 431 #2 Posted March 24, 2014 (edited) I locally purchased four 1/2" X 4 1/2" or 4" (?13 mm x 100 or 115) galvanized carriage bolts, eight nuts and eight washers. Probably over kill but trying to hold the bolt still and slide a heavy weight without pushing bolts out, wow. Some weights may take 7/16" (~11mm), check square "hole" in back wheels. fronts for sure different would have to guess 3/8" (~9 1/2mm) Edited March 25, 2014 by groundhog47 Share this post Link to post Share on other sites
ih674 10 #3 Posted March 31, 2014 I used 12mm coach bolts, squares were a good fit in the wheel centres as said above they are heavy the worst bit is getting them in the middle so they run true, its easier to do it with the wheels fitted and tractor jacked up so you can spin the wheel to check there in line. James 1 Share this post Link to post Share on other sites
