Stretch44875 3 #1 Posted March 20, 2014 I'm going nuts here... Bought a wheelhorse, still have to pick it up. But like a dummy, I didn't take a pic, and forgot to write the numbers down. Looked up every model of wheelhorse on google images to find it, and can't get a match. Here's what I do know. 11hp briggs vertical, wheelhorse 1in axle rear end, approx 32-36 in rear discharge, 8in rear rims. Steel hood. Don't think it's a stamped frame. Looks 70's, early 80's to me. Pretty small, but not as small as a Ranger. Here's the problem. B111 seems to be close, but mine has no foot boards, and NOT a peerless transmission. Shifter is on the floor, not under seat between fenders. I promise to get pics Saturday when I pick it up, and write down the numbers. Until then, anyone have a clue what this tractor is? Thanks, Dennis 1 Share this post Link to post Share on other sites
Stretch44875 3 #2 Posted March 20, 2014 (edited) I'm getting closer! Commando V7 is the right frame, hood, tires, deck and transmission! Is there a model of this tractor that came with a briggs 10 or 11hp? Edited March 20, 2014 by Stretch44875 Share this post Link to post Share on other sites
JimD 3,347 #3 Posted March 20, 2014 Based on your description it sounds like a B-111 as you said. Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,499 #4 Posted March 20, 2014 Dennis, I dont know what it is, but wellcome to red square. Cant wait to see it. Best of luck. Glenn Share this post Link to post Share on other sites
rexman72 210 #5 Posted March 20, 2014 welcome to the group Share this post Link to post Share on other sites
Stretch44875 3 #6 Posted March 20, 2014 Based on your description it sounds like a B-111 as you said. Floor boards are wrong, and mine has shifter is on floor. Maybe someone swapped a 11hp on a V7? I will know more Saturday. Thanks for the welcome! Share this post Link to post Share on other sites
Sparky-(Admin) 24,116 #8 Posted March 20, 2014 Floor boards are wrong, and mine has shifter is on floor. Maybe someone swapped a 11hp on a V7? I will know more Saturday. Thanks for the welcome! Bigger motor=better in my book! It would have been a 7hp Tecumseh (I believe) but a Briggs 11 is a nice upgrade. Mike....... Share this post Link to post Share on other sites
jackhammer 550 #9 Posted March 21, 2014 Stretch44875 , welcome here to our forum. Take a deep breath ,, slow down a bit .. If you bought it,, you will soon see it with correct information. Then you can post your numbers and your pics.. Good luck Share this post Link to post Share on other sites
WH nut 553 #10 Posted March 21, 2014 "What do I have?" The beginning of an addiction 1 Share this post Link to post Share on other sites
Stretch44875 3 #12 Posted March 21, 2014 (edited) "What do I have?" The beginning of an addiction I don't have time for another one! Already have an old house, military vechicle, and race mower addicitions! Don't worry, the wheelhorse is going to stay mostly stock, anything modified will be easily undone... Hopefully my truck will be done at the body shop today, so I can pick it up. Otherwise, I'll drive my crane truck there! Edited March 21, 2014 by Stretch44875 Share this post Link to post Share on other sites
WH nut 553 #13 Posted March 21, 2014 I don't have time for another one! Already have an old house, military vechicle, and race mower addicitions! Don't worry, the wheelhorse is going to stay mostly stock, anything modified will be easily undone... Hopefully my truck will be done at the body shop today, so I can pick it up. Otherwise, I'll drive my crane truck there! That's what you say now.I will check back with you in 6 months Share this post Link to post Share on other sites
posifour11 723 #14 Posted March 21, 2014 You seem to be hooked. Enjoy the ride. Share this post Link to post Share on other sites
Stretch44875 3 #15 Posted March 22, 2014 Got it home, it is a CG7, with a 11hp briggs and battery added. Gas tank appears non-stock, and it's had some painting done. Deck appears in really nice shape. Dosen't look like it sat outside any. Share this post Link to post Share on other sites
Stretch44875 3 #16 Posted March 22, 2014 After some pressure washing. 1 Share this post Link to post Share on other sites
Stretch44875 3 #17 Posted March 22, 2014 (edited) And some other ones sitting in the yard. 800, 520h, and a100. Edited March 22, 2014 by Stretch44875 1 Share this post Link to post Share on other sites
pfrederi 19,375 #18 Posted March 22, 2014 Don't know much about that model WH...but the 5 ton wrecker AWESOME!!!!!!!! Share this post Link to post Share on other sites
Hodge71 691 #19 Posted March 22, 2014 (edited) From my recollection the CG Series (CG7, CG7R, and CG8), tractors were only 1971 and 1972. They were the same as the Commando V7 and V8 in 1969 and 1970 and the A series from 1973 to 1981... Then in 1982 the A series became rear engine riders.......Not sure of much else on those pint size horses..... Edited March 22, 2014 by hodge71 Share this post Link to post Share on other sites
WH nut 553 #20 Posted March 23, 2014 Got it home, it is a CG7, with a 11hp briggs and battery added. Gas tank appears non-stock, and it's had some painting done. Deck appears in really nice shape. Dosen't look like it sat outside any. 0322141412.jpg0322141405.jpg0322141405b.jpg0322141410.jpg Nice Horse Hauler Share this post Link to post Share on other sites
motox25 36 #21 Posted March 23, 2014 Now that's what I need to lift my 60" deck! Share this post Link to post Share on other sites
Stretch44875 3 #22 Posted March 23, 2014 Not quite a 5-ton wrecker, it's actually built on a 2 1/2 ton frame. M108, they only made them for 3 or 4 years. Sure is handy. Got it to run, and drove it around a little. All the gears work, belt or clutch is a little loose. Didn't try the deck yet. Share this post Link to post Share on other sites
popsgarage 1 #23 Posted March 23, 2014 Nice old horse, nicer old wrecker. I did not see an old onan generator, no collection is complete without one or two 1 Share this post Link to post Share on other sites
RMCIII 838 #24 Posted March 25, 2014 Don't know much about that model WH...but the 5 ton wrecker AWESOME!!!!!!!! Yeah what he said!!!! Share this post Link to post Share on other sites
