rtfbg 745 #1 Posted March 20, 2014 Can any of you guys or gals help me date a D200?? Hood decal is "D200 Twin Automatic" Does not have traction brakes Background of headlight panel is black. Kohler engine large number at bottom of IDtag is 8126 main serial number not readable. Previous owner said it was a 1967 model ... but had no data to back that up. Looks identical to a 1978 I used to have. HELP!! thanks!! Share this post Link to post Share on other sites
Shuboxlover 490 #2 Posted March 20, 2014 If the decal is correct it's somewhere between a 1978 to 1981... More qualified people will chime in. GREAT looking horse by the way!!!!! Share this post Link to post Share on other sites
rtfbg 745 #3 Posted March 20, 2014 Thanks ... I found a manual online that had the ID page, and it shows this tag would be a 1978 model. Guess seller was full of it!! No matter, 78 is fine with me!! Share this post Link to post Share on other sites
racin_ny 25 #4 Posted March 20, 2014 Predecessor of the D was the 18 automatic made in 1973 Share this post Link to post Share on other sites
AMC RULES 37,260 #5 Posted March 20, 2014 Nice lookin' , did you bring it home? Share this post Link to post Share on other sites
rtfbg 745 #6 Posted March 20, 2014 Yes ... picked it up on Tue. It looks good in the pics, but it needs a ton of work ... as usual, the steering is shot, the hand controls are all crap and a rear wheel seal is leaking .. all usual D200 stuff!! BUT .. it appears all the parts are there except the fuel tank cap!! lol Share this post Link to post Share on other sites
rtfbg 745 #7 Posted March 20, 2014 Probably going to sell off the mower deck, decent shape, except the typical nose roller issues. Let me know if there is any interest, I'll take some pics. Share this post Link to post Share on other sites
Hodge71 691 #8 Posted March 20, 2014 Definitely not a 1967 as the "true" D series didn't start until 1974. It appears to be a 1978..its id tag should be 81-20KS01..... Looks in great shape. You must have been around these tractors quite a bit. It seems lil you know all the normal issues for a tractor of this era.... Good luck with her!! Share this post Link to post Share on other sites
rtfbg 745 #9 Posted March 20, 2014 In 1977 my father helped me get started in life by assisting me with the purchase of a new Kenworth and trailer. A year or so later, I tried to sort of tried to say thanks, by getting him a new tractor, a D200 from Jack's Wheel Horse in Sarver PA. I found a huge (7 in high) chrome stallion hood ornament at some truck stop and we bolted it on. Looked sweet!! It ran fine, doing tons of mowing and pushing til the early 2000's, when he traded it on a Gravely. We spent a lot of time working on the typical stuff, installing about a dozen engine / pump spline connectors, steering column bushings and other wear stuff. The design engineers forgot one thing about the steering ... it's plenty strong enough for the steering function ... the problem is, the tractor is so friggen big, the wheel ends up being the only available climbing handle!! Not designed for 275lb side loading!! Imagine that!! LOL Share this post Link to post Share on other sites
rtfbg 745 #10 Posted March 26, 2014 I've got another silly question ... the previous owner painted this thing, including the engine, with what I can only guess, was a 10 year old mop!! Where should I begin stripping paint on the engine to find the ID tag??? thanks!! bob Share this post Link to post Share on other sites
wheeledhorseman 579 #11 Posted March 26, 2014 (edited) The Engine ID is on a couple of foil decals on the engine tin just below the spark plug. Here's the originals This is from my '77 D-200 but the arrangment on my '78 is exactly the same - just don't have pics of that ready to hand. Hope this helps. Andy [edit] Re the gas cap gauge the original 13" is NLA but I discovered that Kelch (OEM manufacturer) still do a generic 12" that looks good - and gives you a little 'reserve' after it indicates empty. This size based on the larger gas tank which should be on yours - both my '78 and '79 have the large tank. Edited March 26, 2014 by wheeledhorseman Share this post Link to post Share on other sites
rtfbg 745 #12 Posted March 26, 2014 thanks!! I will gently hit it with some stripper gel and see if something pops up. Otherwise, IK may have to borrow someone elses number to shut up the counter clerk at the Toro dealership Share this post Link to post Share on other sites
pfrederi 21,301 #13 Posted March 26, 2014 You said it didn't have "Traction" brakes...did you mean turning brakes. If it is a 1978 it should have a real brake band on the transaxle. earlier models just used the hydro itself for braking. If it is a 78 the Kohler Spec number should be 532S-53105A Share this post Link to post Share on other sites
rtfbg 745 #14 Posted March 26, 2014 Yes, turning brakes would be the correct term ... no, none on this model, just the drum brake. Share this post Link to post Share on other sites
leereynolds 0 #15 Posted April 10, 2014 I need the quick coupler to a D200 for my tiller. I cannot find the part, is it an option to drill and pin on the spline? Share this post Link to post Share on other sites
rtfbg 745 #16 Posted April 21, 2014 I have another question for the D Gang ... but you can wait a couple days to respond, hopefully this Easter stuff will be gone!!! I need a part number for a D200 brake band. The 1974 parts manual I got from one of you guys is pre-brake days, that unit had the turning brakes. My 78 has the brake band on the trans. Thanks!!! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,533 #17 Posted April 21, 2014 If this tractor is the 91-20KS01 you posted this should take you to the 1979 parts list http://www.partstree.com/parts/?lc=toro&mn=91-20ks01 The 2nd Brake and Motion control page shows the brake band. Garry Share this post Link to post Share on other sites
rtfbg 745 #18 Posted April 21, 2014 Thanks Garry ... I should have looked on the Manuals page first, there's a 78 PL there!! thanks again!! bob Share this post Link to post Share on other sites
pfrederi 21,301 #19 Posted April 21, 2014 (edited) Seems the brake band is NLA...McMaster sells strips of brake lining (I use metal free)....and rivets Edited April 21, 2014 by pfrederi Share this post Link to post Share on other sites
JamesBe1 84 #20 Posted April 21, 2014 Isn't this the same transmission used on all D-series and large C-series? If so, then wouldn't a new or used brake band from one of them work? Just a thought. j Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,533 #21 Posted April 21, 2014 If this tractor is the 91-20KS01 you posted this should take you to the 1979 parts list http://www.partstree.com/parts/?lc=toro&mn=91-20ks01 The 2nd Brake and Motion control page shows the brake band. Garry Your tractor should be a 1979 model with the model number starting with a 9. Serial 05207 has a build date of 8151 - May 31, 1978 Serial 05262 has a build date of 8152 - June 1, 1978 Seriel 0529x has a build date of 8152 - June 1, 1978 - Your's and can't make out the last digit in the serial. Not uncommon to see build dates this early for the following model year. Garry Share this post Link to post Share on other sites
rtfbg 745 #22 Posted April 21, 2014 Thanks guys ... never thought to check McMasters. I've been watching online, most bands are showing round hoops on both ends ... the D has a hoop on one end and an angle with holes on the other. Either put new lining on my band, or cut end off and weld it to a different style. Better sleep on this!! lol thx again!!! Share this post Link to post Share on other sites
