Bjorn72 0 #1 Posted March 14, 2014 Hi !! Can anyone help me with a number or measurment on bearing nr 12 in first picture below, and bearing nr 12 in the other picture below ?? and also sealings nr 13 ?? // Björn // Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,483 #2 Posted March 14, 2014 Toro 5196 has been replaced by 109842 Bearing Ball .750"x1.781"x.610" Rotary 484, Stens 230-033, Stens HD 230-037, Napa 7-04250, Generic 9504AB This one is a guess Toro 106769 Bearing Needle 1.500"x1.875"x1.250" Caged Open It may be a Torrington J-2420 Take the old ones with you to a supplier for comparison. There may be numbers on the ends of the bearings that would be a big help. Garry Sorry - forgot the seal Toro 6663 Seal 1.500"x1.878"x.250" CR Chicago Rawhide or SKF number 14810 Should add that the original seal may be a different width or thickness. I got these dimensions from a Chicago Rawhide catalog and that is the seal they replace the Toro 6663 with. Share this post Link to post Share on other sites
