Rideking
Aftermarket Tiller Belt?
Rideking
I know there have been many posts made about tiller belts, and I've searched high and low through the archives, and still have questions! I have a 36" tiller that I've recently put back together (thanks to the help of a few RS members!) that I would like to mount on my 310-8. I'm down to the belt, I believe I need a Toro 110265? Now I don't have a problem buying this online, but would rather buy locally - however my local Toro dealer is clueless. Is anyone aware of, or have experience with an aftermarket tiller belt?
I've seen the following referenced as potential cross overs:
Pix A139:
http://www.vbelts4less.com/A139--A-SECTION-V-BELT_p_12851.html
Napa 6652BR:
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Belt-Alternator/_/R-NBH6652BR_0438715568
doc724
I bought the Toro belt thru MowPart.  Jack's Small Engines, Partstree or RCPW probably has them as well
rwilson
The Toro dealer is clueless???? He cant get on the Toro parts viewer and look it up? You will need to give him your serial numbers from the tiller.
can whlvr
it looks like your part nuber is correct,he should be able to order it with that number
bowtieguy
My Toro dealer will order any WH part that I want (if available)....have never found a WH belt to be NLA...so say goodby to your dealer and find another one.
There are still several good WH dealers in MO....if you don't find one, try Lumax in Belton, MO 816-331-1843.
I just bought a belt for a rear tiller on a Raider 10....belt was pricieeee....but it fit the pulleys without any slipage....ordered on a friday...got it on tuesday.
I like to support my local dealer on all WH belts as I think they last forever.....just sayin'
