Free Range 0 #1 Posted March 10, 2014 Does anyone have a build along, or diagram, or pictures of how this is suppose to work. I can lift my mower deck, sort of, doesn't seem to lift very high. But there looks like there used to be some sort of lifting mechanism attached to the rear also, for lifting a garden plow or other rear attachments. However on mine there doesn't seem to be much of it left. Would like to restore it so I can use a garden plow at least. Share this post Link to post Share on other sites
Don1977 605 #2 Posted March 10, 2014 There are two types Slot and Clevis for garden plow attachment. Each can be found in the Implement Manuals section. For more help post pictures of what you have will get you better answers as to what you need. Share this post Link to post Share on other sites
Free Range 0 #3 Posted March 10, 2014 thanks I will post pics ASAP Share this post Link to post Share on other sites
can whlvr 994 #4 Posted March 11, 2014 if you look under at the area that has the (arms that actually hook the chain or other implements)this is the bell crank,theres 2 levers,one is used to lift the deck,plows,,the other is for rear attachments,snow throwers,its fairly easy to see on the earlier c,smuch easier than the newer models Share this post Link to post Share on other sites
Kelly 1,037 #5 Posted March 11, 2014 What year is the C-160 some you can add a bell crank under the fender to aid in lifting others only a cable run to the back Share this post Link to post Share on other sites
Free Range 0 #6 Posted April 1, 2014 Ok sorry for the delay, what do you guys think, is there something I can do to fix this so I can raise and lower rear attachments? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,012 #7 Posted April 1, 2014 Clevis hitch http://www.wheelhorseforum.com/files/file/1731-hitch-rear-clevis-1994-2009-implement-8-5518-85518-ipl-3322-959pdf/ Slot hitch Garry Share this post Link to post Share on other sites
Kelly 1,037 #9 Posted April 1, 2014 Your tractor is a C-161 not a C-160 Share this post Link to post Share on other sites
