NJhorses 12 #1 Posted March 9, 2014 I have a c160 that the tow valve will not turn. I was wondering if anyone has had this problem and how they solved it. Share this post Link to post Share on other sites
jeremi3210 742 #2 Posted March 9, 2014 Yep lots of pb blaster pentrating oil. I grabed mine with a vice grips and slowly worked it loose. Just dont force things take it slow maybe let it soak for a week before you try it. Share this post Link to post Share on other sites
can whlvr 994 #3 Posted March 10, 2014 I had to make a special blade that fit the slot and then I could put a pair of vice grips on the metal blade Share this post Link to post Share on other sites
NJhorses 12 #4 Posted March 11, 2014 Thank you for the help. Started the PB blaster today. Will be making or finding a well fitting blade to turn it with Share this post Link to post Share on other sites
boovuc 1,090 #5 Posted March 12, 2014 I had a C-120 that had a locked up tow valve. I used cotton balls soaked in PB blaster and had them on the valve using a little metal bar leaning against the tractor to hold it in place. It took the better part of a week but it did help keep the blaster on the threads and it did let go. Share this post Link to post Share on other sites
