limited12 360 #1 Posted March 3, 2014 i have a comando v7 that i am working on, the engine is bad and can not find a replacement, this tractor will only be used to pull the grand kids around in the trailer and riding at some shows, i was looking on e-bay and found aKohler Courage XT Series 8TP 25mm x 3-5/32" Vertical Shaft Engine #XT800-2017, will this work with out to many modification Thanks for any help or advice, if everyone suggest a different direction i am open to all Thanks again Share this post Link to post Share on other sites
oaktown1987 82 #2 Posted March 3, 2014 Those engines are junk I worked at a mower shop and we got a lot of them In Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Desko 624 #3 Posted March 3, 2014 Find a nice 5 hp Briggs or an 8 hp electric start Briggs. Share this post Link to post Share on other sites
wheelhorse66 10 #4 Posted March 3, 2014 Shoot for just what you Want to do I would just get a predator engine.you can get it at harbor freight for 119 bucks,I have one on a tractor and it runs and pulls just fine,and there easy on gas to. Share this post Link to post Share on other sites
limited12 360 #5 Posted March 3, 2014 thanks guys, will go and check the predator out Share this post Link to post Share on other sites
wheelhorse66 10 #6 Posted March 3, 2014 Its pretty good for the money,I put one on a 701,you will have to make a base plate,but it ain't hard to drill a couple holes. Share this post Link to post Share on other sites
slammer302 2,156 #7 Posted March 3, 2014 I've used several they are a great motor for the money only one thing the pull start is weak but they are easy to fix Share this post Link to post Share on other sites
squonk 43,812 #8 Posted March 3, 2014 If you want to go original I know where there is a Commando V7 sittin in the weeds. They want too much for it, that's why it's still sittin but hey, you never know! Share this post Link to post Share on other sites
limited12 360 #9 Posted March 3, 2014 Thanks Mike I found one here local also the other day, it is in really bad shape and they want way to much. Thanks Share this post Link to post Share on other sites
dodgemike 52 #10 Posted March 4, 2014 Ditto on the Predator engine. Got one for 99 bucks with coupon. Put it on a 27" walk behind snow blower. 2 hp less than the Briggs that ate a ring. Starts first pull and plenty of power. Sent from my SCH-S720C using Tapatalk 2 Share this post Link to post Share on other sites
