Pace F20s 0 #1 Posted February 27, 2014 I have a Kohler k301 that is currently .020 overbored. Can it be bored out to .040 over (safely)? Thanks, Roland Share this post Link to post Share on other sites
953 nut 63,102 #2 Posted February 27, 2014 Have you found a .040 over piston? I don't recall ever seeing more than a .030 over. Share this post Link to post Share on other sites
rmaynard 16,700 #3 Posted February 27, 2014 (edited) I have never seen a piston and rings larger than .030 over. I think that if you don't have enough cylinder to work with to get a good .030 bore, you will have to have it sleeved. I which case, I would look for a good block that I can have bored to .010. It will end up costing you less. Edited February 27, 2014 by rmaynard Share this post Link to post Share on other sites
Pace F20s 0 #4 Posted February 27, 2014 I found one on ebay at this link. Seller has over 60k feedback at 99% +. http://www.ebay.com/itm/141204327453?_trksid=p2055120.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Share this post Link to post Share on other sites
rmaynard 16,700 #5 Posted February 27, 2014 That is amazing. I have never seen that before. I think I will defer to one of our engine specialists to see if there is really enough material to bore that large. Share this post Link to post Share on other sites
520HC 208 #6 Posted February 27, 2014 I would think your cylinder will clean up at .030. Have you measured it? Share this post Link to post Share on other sites
Pace F20s 0 #7 Posted February 27, 2014 Have not accurately measured it yet. That will be up to a machine shop. Thanks for the replies. Share this post Link to post Share on other sites
AMC RULES 37,250 #8 Posted February 27, 2014 I would think that .10 or .20 would constitute a "safe" overbore. Share this post Link to post Share on other sites
leeave96 495 #9 Posted February 27, 2014 (edited) I would think that .10 or .20 would constitute a "safe" overbore. Actually the kohlers are designed to be bored over at .010, .020 and .030 and they have piston/ring sets available. They also use to have rings (not sure about the piston) that is .003 over for when it was appropriate to hone the cylinder on the original bore. When I read some of the incredible hours, 2000+ and more some folks are getting on their Kohler engines and then getting the same on a rebuild - that's a lot of seat time! Edited February 27, 2014 by leeave96 1 Share this post Link to post Share on other sites
MalMac 1,333 #10 Posted February 27, 2014 Like said, I believe there is a reason the Kohler engineers design the max bore being .030. anything else past that Is just too thin on the cylinder wall. If you could go over having such a thin wall I would imagine would get into cooling problems not to mention uneven wear. Share this post Link to post Share on other sites
bmsgaffer 2,065 #11 Posted February 27, 2014 If have a complete K301 for sale right now if you want to go that route. I am have not torn into it to see if it has been bored yet, but it runs great with no smoke so it should not need a rebuild for a while. Share this post Link to post Share on other sites
oaktown1987 82 #12 Posted March 1, 2014 I've heard u can safely bore a 12 out to a 14 bore Sent from my iPhone using Tapatalk 1 Share this post Link to post Share on other sites
Don1977 605 #13 Posted March 1, 2014 I've heard u can safely bore a 12 out to a 14 bore Sent from my iPhone using Tapatalk You would also need a 14 HP crank shaft as the 12 HP crank shaft isn't heavy enough as part of the weight has been milled off. Share this post Link to post Share on other sites
oaktown1987 82 #14 Posted March 2, 2014 I believe u still use the 12 hp rod Sent from my iPhone using Tapatalk 1 Share this post Link to post Share on other sites
oaktown1987 82 #15 Posted September 27, 2014 Even if it needs sleeved I wouldn't throw it out Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Fordiesel69 271 #16 Posted September 27, 2014 .040 is not a problem unless the cast iron is porus. If you get it past .030 and see pitting in the cylinder, then you know you have one of these bad blocks. But most K301's could be bored to a K321 and the crank changed. 1 Share this post Link to post Share on other sites
