pezsox 31 #1 Posted February 25, 2014 I am looking for a pic that shows an RJ58 belt. All of the pics I find show them with a belt guard covering the pulleys and belts. I just want to get a good idea of the tension and the roundrod guard. Almost there... Share this post Link to post Share on other sites
Lane Ranger 11,960 #2 Posted February 26, 2014 Not much of a close up but this may help! This shows the drive belt and three pulleys with the guards off . I was installing my front cutter bar on the 1958 RJ. 1 Share this post Link to post Share on other sites
buckrancher 2,696 #4 Posted February 26, 2014 (edited) click on this one and it gets bigger Edited February 26, 2014 by buckrancher 2 Share this post Link to post Share on other sites
AMC RULES 37,259 #5 Posted February 26, 2014 OK Brian... you know, everybody likes a show off. Share this post Link to post Share on other sites
pezsox 31 #6 Posted February 26, 2014 I mainly was wondering what the tension on the belt should be when installed. Obviously that could have a lot to do with length of belt, and engine placement. As looking at pics I see there is no standard. It runs well and doesn't "miss" so I guess I go with it? The other question I had is where the "bent rod guard" goes. I didn't know if it rotates under the belt or if it is in the correct location? Share this post Link to post Share on other sites
buckrancher 2,696 #7 Posted February 26, 2014 the other bent belt rod is for a attachment like a mower deck or sickle bar the belt cover is used for the drive belt Share this post Link to post Share on other sites
Lane Ranger 11,960 #8 Posted February 26, 2014 (edited) I found a few more pictures of the belt, the homemade "bent rod guard" Brian has in his photo for the attachment belt and two belts running off the motor pulley. Edited February 26, 2014 by Lane Ranger Share this post Link to post Share on other sites
pezsox 31 #9 Posted February 26, 2014 ok perfect. The guard was with the motor but I couldnt remember the angle it attached at. So for a single motor it doesn't look like it does much. thanks Share this post Link to post Share on other sites
Waynesmith 0 #10 Posted March 2, 2020 What size is the idler pulley ? Diameter? Share this post Link to post Share on other sites
Horse Play 393 #11 Posted March 4, 2020 I'd have to go measure, but if you need a new pulley this is what I used: https://www.wheelhorsepartsandmore.com/#!/RJ-Pulley-WH-3542/p/85606036 Share this post Link to post Share on other sites
