wheelhorsebo 20 #1 Posted February 22, 2014 Tap bolts 7/16 20 thread x 2 in Any one know where to get them. I looked every where and I can only get them in 400 gross. I only need ten ? Share this post Link to post Share on other sites
rmaynard 17,429 #2 Posted February 22, 2014 (edited) McMaster & Carr Part # 92865A318 Edited February 22, 2014 by rmaynard 2 Share this post Link to post Share on other sites
n1defan 47 #3 Posted February 22, 2014 Mid State Bolt and screw! Share this post Link to post Share on other sites
Kelly 1,038 #4 Posted February 23, 2014 Got mine at Fastenal, I picked up my lug nuts at the local auto parts store even chrome ones $0.75 each Share this post Link to post Share on other sites
wheelhorsebo 20 #5 Posted February 23, 2014 Thanks for all the leads n1defan i will order on that link Thanks again Share this post Link to post Share on other sites
Tankman 3,528 #6 Posted February 23, 2014 (edited) Local auto parts stores usually have them in stock. I use 7/16-20 x 1-1/2" long bolts, small flat washer under the bolt head and Threadlocker® Blue on the bolt threads that will engage the hub. The small flat washer compensates for irregular surfaces on the hub. Like using lug nuts (7/16-20 open end lug nuts)! Much easier to hang a heavy tire on the Horse. Edited February 23, 2014 by Tankman Share this post Link to post Share on other sites
doc724 927 #7 Posted February 23, 2014 I think I read somewhere where on RS that the bolts should be 1.5 inches long. Tankman also agreed. I have not verified this, but my experience is that at some length the bolts will not be threaded the full length. They have to be threaded full length or you will not bottom the bolt head on the back of the hub flange. Getting the lug nuts may be a bit more challenging. I found them on ebay for $13 for 20. I need to go to one of the big tire stores here in the east to see if maybe they can sell lugs nuts for less (they must buy them in bulk), however, 7/16-20 is kind of obsolete now, was mainstream for GM in the 80's. Share this post Link to post Share on other sites
squonk 47,410 #8 Posted February 23, 2014 (edited) Get your lug nuts at a Napa. Get them for a 72ish Camaro. Cheap.They should be in stock. #641-2022 my Napa has 25 of them. About a buck 75 Edited February 23, 2014 by squonk Share this post Link to post Share on other sites
wheelhorsebo 20 #9 Posted February 23, 2014 I know what u are saying but I am adding calls to mine and the way it works is u have to install wheel then adaptor then lug nuts after coming thru the back of hub with bolts. The longest ones I could get was 1 3/4 I need 1/4 more thread on bolts so it will use all the lug thread. That is shall wheels Duall wheels Share this post Link to post Share on other sites
squonk 47,410 #10 Posted February 23, 2014 I got my longer bolts (2") from McMaster-Carr for my C-145. I have 23x10.50 ag's on it and after putting chains on the chains hit the gas tank. So I had to use wheel spacers and then needed the longer bolts. Share this post Link to post Share on other sites
wheelhorsebo 20 #11 Posted February 23, 2014 I have 23x8.5x 12 Squalls on mine Look at wheelhorsebo And u can see adaptors and tires Dual tires Phone does not want to Type right Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,358 #12 Posted February 23, 2014 Leaf spring center bolts come in 7/16-20 and are a reasonable source for studs. They usually have a lot of thread so make quite a few. A bit of the good Locktite and they are good to go. Garry Share this post Link to post Share on other sites
N3PUY 1,031 #13 Posted February 28, 2014 For rear wheel studs this is what I used ... $8 for 10 nuts and bolts. Share this post Link to post Share on other sites
