pezsox 31 #1 Posted February 22, 2014 I have a Kohler K91 that I am having an issue with. I have 2 wires that come from underneath the flywheel. One goes to the sparkpluge and the other goes to the points. I then have 1 wire that goes from the points to the switch on the dash. I thought I had a bad switch so I went and got a replacement. The "original" only had one wire hookup terminal. I hooked it up exactly as it was but now the switch still does not turn the tractor off when moved into the off position. Is there supposed to be 2 wires? A ground? are the points bad? I assume the points are good since the tractor runs fine. When I push down on the "stop" button on the points cover that doesnt always stop the engine either. Any suggestions? Share this post Link to post Share on other sites
buckrancher 2,695 #2 Posted February 22, 2014 check the wiring at the points for a bad connection also is the new switch you bought a self grounding switch and if it is besure you are getting a good ground thru the switch body to the hood to the frame of the tractor Brian 1 Share this post Link to post Share on other sites
Jake Kuhn 1,598 #3 Posted February 22, 2014 yep, as brian said you probably need a ground. Most of the new switches all have the 2 terminals. I usually run the ground to the points cover. Share this post Link to post Share on other sites
Eboy 38 #4 Posted February 22, 2014 On my rj-58 the on/off switch had one of the two terminals was soldered so it was grounded. Share this post Link to post Share on other sites
