Irish Rover 14 #1 Posted February 18, 2014 Hi everybody... I am a new member to R.S. I have recently picked up a 1975 C-100 and a single stage snow blower (I don't know the model #) for $350. I bought it to clean up around our small airport in West Michigan. The maintenance guy at the airport has created a mess around our hangars with his questionable plowing practices. I would like to attack the windrows over the next couple days so the warmer weather can have a chance to help with the snow. The windrows are not huge, but I was wondering if there is a best practice to clear them. I am assuming I will have to bust them up with a shovel and then blow the knock down away. I don't have a plow. I thought it wouldn't hurt to beg for some tricks. Casey C-100 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,221 #2 Posted February 18, 2014 That snowthrower should be one of these 1983 model 06-42ST03 - first model to use skids instead of wheels 1984-87 model 06-42ST04 1987-89 model 06-42ST05 1990 model 06-42ST06 - last model to use a cable to turn the chute Garry Share this post Link to post Share on other sites
Hodge71 691 #3 Posted February 18, 2014 (edited) Casey, with it being an 8 speed I would say the best way to attack it is head on. No need to bust anything up with a shovel unless you are dealing with solid Ice and then you shouldn't be blowing it anyhow. I would say best thing to do is run at full throttle, put the transmission in low range and start out in second gear. Put the pile right in the middle of the blower and chug through it. If its too fast and bogging the engine horribly, drop to first gear. Just be patient. Your tractor has a Kohler…Its a good engine and it will chew through your mess. Post some pics too, before, after, action shots during…we are suckers for pics and vids. Good luck and Edited February 18, 2014 by hodge71 1 Share this post Link to post Share on other sites
AMC RULES 37,259 #4 Posted February 18, 2014 Got a pict of those windrows to share here Casey? Share this post Link to post Share on other sites
Irish Rover 14 #5 Posted February 18, 2014 I do t have a photo of the windrows. They are only a few feet high. I tested one with a shovel and they are not rock solid. I think the blower will chew through some of it on its own, but I have a hunch I will have to knock some down with a shovel. If I had another horse with a plow, I would be all set. Sounds like a purchase for next year. Casey C-100 I'll send some pics of the carnage. Woo Hoo. Casey C-100 Share this post Link to post Share on other sites
SousaKerry 503 #6 Posted February 18, 2014 (edited) I have busted through 5' snow piles left from snow plows with my blower(same model) takes some time but it will chew through it. I ram the pile let the blower chew till it clears and back up and ram again when it get real tough. Biggest problem is when the chute is shorter then the pile your chewing through. You can also try running the blower in the up position take the top off then back up and lower it to get the rest. Here is mine chewing through ice and drifts in my yard Edited February 18, 2014 by SousaKerry 1 Share this post Link to post Share on other sites
Sparky-(Admin) 25,196 #7 Posted February 18, 2014 You may have traction issues without weights and tire chains. And of course.... Mike........... Share this post Link to post Share on other sites
Irish Rover 14 #8 Posted February 19, 2014 I have chains mounted but no weights. So far I have had good traction with just the chains. I got most of the area cleaned up tonight. Here is a picture of the horse sheltered under a friendly wing. Casey C-100 Casey C-100 1 Share this post Link to post Share on other sites
Kelly 1,038 #9 Posted February 19, 2014 I use my blower to take big piles down, use it in the up position, then back up lower and finish up, if you need or want a plow I have a small WH salvage here in MI and have a few plows. Share this post Link to post Share on other sites
pfrederi 20,477 #10 Posted February 19, 2014 If you are attacking hard plow piles I would remove the side wings on the blower. The put a big strain on a weak point of the blower assembly and you make break the weld between the top of the blower body and the top front of the end plates. 1 Share this post Link to post Share on other sites
rexman72 210 #11 Posted February 19, 2014 the snow keeps coming and coming Share this post Link to post Share on other sites
JC 1965 1,545 #12 Posted February 19, 2014 Good luck with the snow piles and Share this post Link to post Share on other sites
Irish Rover 14 #13 Posted February 19, 2014 What are the opinions of the side wings? They sure do like to grab the snow and pull the tractor to one side or the other. Do you prefer to run with them on or off? Casey C-100 Share this post Link to post Share on other sites
AMC RULES 37,259 #14 Posted February 19, 2014 (edited) Looks like you're gonna need an air horse too. Edited February 20, 2014 by AMC RULES Share this post Link to post Share on other sites
Irish Rover 14 #15 Posted February 19, 2014 New Ags going on soon Casey C-100 2 Share this post Link to post Share on other sites
boovuc 1,090 #16 Posted February 20, 2014 Ahhhhhh. Your horse is making friends with a Cessna! Share this post Link to post Share on other sites
can whlvr 994 #17 Posted February 20, 2014 the wings are great if you arnt doing anything but staying in the already blown area,i just bent one of my throwers really bad,bent the right side 90 degrees to the body,kept catching things like rocks around the flower bed,and all the frozen banks we have,so I agree with paul,take them off if your working hard snow,you can break welds also Share this post Link to post Share on other sites
Irish Rover 14 #18 Posted February 20, 2014 Before and after photos. The knucklehead plow driver continues to p#%£ me off. Casey C-100 Share this post Link to post Share on other sites
AMC RULES 37,259 #19 Posted February 20, 2014 Yep, frozen like a rock...take your time tryin' to blow that stuff off. If you can wait till the early afternoon, might be a little easier on your equipment after it warms up a bit. Share this post Link to post Share on other sites
