ihsig@sbcglobal.net 0 #1 Posted February 17, 2014 I have a 308-8 from the mid-80's and I just picked up a 6-3211 snowthrower attachment. I can't seem to get it to work right. I am wondering if I am missing anything or if I have the pulley running correctly. Any help would be greatly appreciated. Share this post Link to post Share on other sites
Lane Ranger 11,637 #2 Posted February 17, 2014 That model snowblower is for the older Wheel Horse tractors -pre-1972 or so that did not have that type of attach-a-matic in front. You may be able to attach -should go on the frame with the front attach-a-matic removed but I have never done this before. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,757 #3 Posted February 17, 2014 The 6-3211 is for the Lawn Ranger models. Here is the manual Here is one that was made for the 308-8 Garry Share this post Link to post Share on other sites
ihsig@sbcglobal.net 0 #4 Posted February 17, 2014 Thanks for the replies...so I guess I am out of luck and need to put the plow back on. The only thing I tried that made it work was to figure-8 the belt so the auger spins correctly. Share this post Link to post Share on other sites
leeave96 490 #5 Posted February 17, 2014 I took an older model blower that was meant to be bolted on and cut the frame, drilled some holes at the end of the frame and inserted a piece of round bar stock through it so it would fit the front tach-a-matic. The local napa place let me try several belts until I found one that fit. May be worth a try. Share this post Link to post Share on other sites
