rocking 416 1 #1 Posted September 9, 2008 ok, i tore down my c81's 8 speed trans . it works goes in and out of gear . foward and backwards. but only one wheel spins i think i have somthing wrong with the diff? any ideas?? :banghead: Share this post Link to post Share on other sites
kpinnc 14,885 #2 Posted September 10, 2008 Gonna go out on a limb here, so forgive me if I am barking up the wrong tree... You didn't say when only one wheel spins, so I assume it's doing so with the rear wheels blocked up off the ground, or in a poor traction situation. That said, IF the rear wheels are indeed off the ground, it is not unusual. The C81 didn't have the limited slip differential, so in an instance where wheel slip is allowed, only one wheel will spin. This is especially true if the wheels are off the ground. If they are blocked up off of the ground, you should be able to stop the wheel that is turning (being very careful not to do anything that will injure yourself, or knock the tractor down off the blocks), and the other wheel should begin to spin instead. Again, be very careful. Use a wood block against the side of the tire, or something similar. DO NOT grab the spinning wheel with your hand. The inertia of the spinning tire is certainly enough to pull your arm under the fender, etc... It is a good idea to do this with the tranny in the lowest gear, so the wheels will spin more slowly. Good luck, Kevin Share this post Link to post Share on other sites
rocking 416 1 #3 Posted September 10, 2008 nah what it does is, let say for expample drive up ramp to load on the trailor. one wheel spins the other wheel does nothing . to be exact the left wheel spins right one does nothing. im purdy sure i have the bolts in the differntial to tight. i think there all limited slip. that would make sense transfer power from wheel that slips to ones that grip. my other c81 does fine one hills an the trailor ramp. Share this post Link to post Share on other sites
oldandred 15 #4 Posted September 10, 2008 nothing is wrong with it. just think of a car rear end get it stuck and one wheel spins right yep thats right now with a locking rear both wheel will pull like on my chevy truck with the locking rear mash the gas and what ever way the wheel is pointed is were the truck is going and fast. :banghead: Share this post Link to post Share on other sites
oldandred 15 #5 Posted September 10, 2008 I just looked it up in the book and if yours is a 1978 with a id number of 81-08k801 it is not a locking rear its a 103916 rear end or trans axle Share this post Link to post Share on other sites
rocking 416 1 #6 Posted September 11, 2008 it dosent seem like my other c81. wish i had a diagram on how the differential goes toghter i think my bolts are to tight . guess i need to tear it down and learn like i always do. TRIAL AND ERROR :imstupid: Share this post Link to post Share on other sites
Buzz 502 #7 Posted September 11, 2008 wish i had a diagram on how the differential goes toghter i think my bolts are to tight . guess i need to tear it down and learn like i always do. TRIAL AND ERROR Here's the link to a transmission manual for you so you don't have to do it by trial and error: https://lookup3.toro.com/request/filechek.c...=Toro&PubType=9 Share this post Link to post Share on other sites
rocking 416 1 #8 Posted September 11, 2008 Thank you buzzz ...ill let you guys know in a few days how it turns out Share this post Link to post Share on other sites
Kelly 1,033 #9 Posted September 12, 2008 Why do you think you have the bolts too tight? maybe you put the diff. in backwards, the head of the bolts will hit and the diff will not turn. Share this post Link to post Share on other sites
rocking 416 1 #10 Posted September 12, 2008 all i know is. the left wheel turns. the right one does nothing....its dosent seem to want to climb hills or anything i need to tear it down Share this post Link to post Share on other sites
Curmudgeon 28 #11 Posted September 12, 2008 Simple check here. Jack it up with both wheels off the ground. With the engine OFF and in gear, turn either wheel by hand, if the differential is working properly, the other wheel will spin in the opposite direction. If it does anything else, something is wrong. Share this post Link to post Share on other sites
