1968charger12 0 #1 Posted September 9, 2008 :banghead: can anyone help me. my tractor doesnt go in forward anymore or it goes then stops and kinda jerks back and forth but goes fine in reverse does anyone know how to fix it Share this post Link to post Share on other sites
Teddy da Bear 11 #2 Posted September 9, 2008 Charger.....the folks here might need a little more info. Is it a manual or hydro transmission? Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #3 Posted September 9, 2008 His user name is 1968charger12 and you're asking if his tractor is a manual or hydro? "1968charger12" - Has the filter and fluid been changed in the recent past? That should be the second step after you determine if the drive belt, tensioner, and pulleys are in good condition. :USA: Share this post Link to post Share on other sites
Jim_M 179 #4 Posted September 9, 2008 I have one thing to add to TT's advice, check for a sheared or badly worn axle/hub key. It's a long shot, but it's possible that it could let the axle spin in the hub going forward but roll into a different position and catch in reverse. Share this post Link to post Share on other sites
Duff 206 #5 Posted September 9, 2008 Just wanted to add my , 1968charger12! Duff Share this post Link to post Share on other sites
Sparky-(Admin) 23,153 #6 Posted September 10, 2008 Charger.....the folks here might need a little more info. Is it a manual or hydro transmission? The Chargers are hydro's and the Raiders are Manuals. Mike........... Share this post Link to post Share on other sites
pond195520032003 27 #7 Posted September 10, 2008 :banghead: 1968charger12 if you can get them :USA: Share this post Link to post Share on other sites
Rod(NASNUT) 1 #8 Posted September 10, 2008 I have one thing to add to TT's advice, check for a sheared or badly worn axle/hub key. It's a long shot, but it's possible that it could let the axle spin in the hub going forward but roll into a different position and catch in reverse. Yes the same thing happened to my Charger 9. Share this post Link to post Share on other sites
Teddy da Bear 11 #9 Posted September 10, 2008 Thanks Mike.. Heck..I did not know. But I was thinking if it is a hydro....something out of adjustment or dirty filter/fluid or if there is a connecting pin somewhere it might have come out. Just my opinion based on my GT-14..... Share this post Link to post Share on other sites
1968charger12 0 #10 Posted September 11, 2008 sundstrand hydro Share this post Link to post Share on other sites
1968charger12 0 #11 Posted September 11, 2008 i just replaced the axel seal oil oil filter and hub keys but ill see if its that Share this post Link to post Share on other sites
1968charger12 0 #12 Posted September 11, 2008 1968charger12 if you can get them it wont let me put my pics on for some reason i dont think its the right format Share this post Link to post Share on other sites
Teddy da Bear 11 #13 Posted September 11, 2008 There are size restrictions for pics. They have to be 56k or under in file size. That is the equivelant to 512 x 386 I believe in pixel size. Reduce them and try it one at a time. Share this post Link to post Share on other sites
1968charger12 0 #14 Posted September 11, 2008 I have one thing to add to TT's advice, check for a sheared or badly worn axle/hub key. It's a long shot, but it's possible that it could let the axle spin in the hub going forward but roll into a different position and catch in reverse. thanks that is what was wrong with it i would never have guessed thats what it was thanks Share this post Link to post Share on other sites
